Home > General > Loads of water and no power steering
danboy
Hi Lads
need your help, I'm working away from home this week and the wife rang saying the car has broke down, luckily just turning onto the driveway
so, 2007 RRS HSE, as she was pulling onto the driveway she notice a massive load of steam coming from under the bonnet, (Temp gauge was normal) then an immediate loss of power steering,
limped it 3-4 meters onto the drive and switched it of, she said the driveway was completely soaked as it has appeared to have dumped the entire coolant contents !!!!
what the hell do you think has happened, I'm thinking auxiliary belt has snapped (power steering loss) and somehow split a hose during it snapping !! Possible ???
HELP!!!! 2007 RRS HSE
Post #517834 Tue Feb 14 2017 10:27pm
DrRob
Don't drive it.
Do you have AA or RAC ? Get them out to inspect and diagnose issue if you have.
Might just be a hose and belt - can you ask wifey to FaceTime / Skype so you can try and see for yourself..? Visitor from fullfatrr.com
Post #517836 Tue Feb 14 2017 10:43pm
danboy
can't FaceTime, the phone signal is awful where i am, its going to have to wait until i get home, god i hope its just a belt and hose.
proper worried about it
thanks for the reply
luckily i have 6mths warranty on it as we only purchased it in December 2007 RRS HSE
Post #517838 Tue Feb 14 2017 10:46pm
Socast
The steering going and water everywhere means the auxilary belt has either gone or the tensioner, the fact that it was only driven for a short period should mean all is well (depending on what has broken to cause the leak).
I've not heard of it, but it could be the bearing has collapsed in the water pump. That would cause your leak and loss of steering.
Post #517863 Wed Feb 15 2017 9:11am
Disco_Mikey
Seen a few water pumps collapse, throwing the belt off Thumbs Up
Good news is its a relatively cheap repair
Post #517872 Wed Feb 15 2017 10:08am
danboy
Hi guys
Right its a long story but the garage has still not collected the car for repair, they are collecting in the morning, i have had chance to have a proper look as to what has failed.
so with a torch looking down from the top of the engine between the rad and the lump i nearly had a heat attack !!!
the entire water pump is laying at the bottom!!!!!! i can see 2 sheered bolts laying next to it, the belt isn't snapped just all wrapped and tangled, 2 of the fins on the fan are damaged etc,
what in gods name would make that happen ???
cheers 2007 RRS HSE
Post #518260 Sun Feb 19 2017 6:36pm
