![]() | Home > Technical > Location of front heated windscreen fuses |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5091 ![]() ![]() ![]() |
try looking at the symbols on the lid in the fusebox under the bonnet.
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 440 ![]() ![]() ![]() |
Cheers Andy, the fuses are different on the MY12. I think I may have identified them but need to confirm so I can do some accurate testing.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5091 ![]() ![]() ![]() |
They are in a bank of six fuse locations to the rear and slightly left, sort of pink square 30amp rated fuse position 2 is right hand side and six is left hand side.
Cheers Col, I suspect it was the J type fuses, but they are both in tact, so I suspect the relay may be faulty. I have no voltage at the right hand window connector. If you have the TSB, that would be excellent.
turn the heater on and see if there is voltage present at the fuses |
There is power at both the fuses so suspect it may be the relay. I don't have any schematics to see how the power is delivered to the screen. MY12 RRS HSE
PM me a email address and I will send you one as pdf file.
Bill Portland Member Since: 01 Feb 2017 Location: Dorsetshire Posts: 395 ![]() ![]() ![]() |
My driver's side heated screen is not working. Did this thread resolve whether each side is fixed separately?
Hello Bill
Thanks, how does the pillar trim come off? Merc C220 estate Sport AMG
Gently prise out the Oval Airbag Grommet at top of pillar, underneath is a torx headed screw can't remember if it's 20 or 25, remove it, should stay in the trim as it's held in place by the plastic. The just gently pull out from the top as has a small plastic locating lug at the top and lift upwards out of locating recess at the bottom.
Thanks for that, I'll have a go this evening Merc C220 estate Sport AMG
It seems that the Incredible Hulk is employed on the LR assembly line and is responsible for putting in the torx screws mentioned above. They're solid!
I normally use a 3/8" ratchet drive on them and its easy |
