![]() | Home > In Car Electronics > SAT NAV Display backlight |
It could be just dry joints if intermittent, but a real sod to get out and check/repair and costs a lot if you pay. May need a new light source LED if edge lit or LCD or plain old tube backlight all depending on model Year fitted. John
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
Is it that the perspex in front of the ambient light sensor dirty ?
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5116 ![]() ![]() ![]() |
Where is the AL sensor ?
little clear blob at the bottom of the rev counter. |
scarey Member Since: 07 Jan 2011 Location: in the cloud Posts: 411 ![]() |
you normally get a dim display when its cold and the battery power is prioritised by other ecus..if you stop and restart the display should go back to normal brightness.... |
