Home > Technical > Positive Crankcase Ventilation system
shakeapaw
I have just discovered an oil leak on my drive, on closer inspection it seems that Oil is being forced out of the dipstick, I then reseated it, took it for a quick blast with full throttle and the dipstick popped up again. there is also vapour rising from the dipstick. Despite searching the internet I have no real idea where the Positive Crankcase Ventilation system filter or pipes are, as they may be clogged.
Anyone any ideas? 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #517713 Mon Feb 13 2017 10:42pm
Does this help?
http://www.rrsport.co.uk/gallery/albums/us...20PCVt.pdf 2012 SDV6 - it's missing a couple of cylinders
Post #517716 Tue Feb 14 2017 12:45am
shakeapaw
hmm, not sure, that looks like the old 4,4v8, not the modern 3,6, but will have a look tomorrow, thanks 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #517719 Tue Feb 14 2017 2:16am
have a look at the workshop manual, see below --
Post #517725 Tue Feb 14 2017 9:04am
It's the 3.6 TDV8.
It's from the workshop manual. You can buy your own for a fiver off ebay... Whistle
Or download the one linked above if you're tight. Wink 2012 SDV6 - it's missing a couple of cylinders
Post #517732 Tue Feb 14 2017 10:27am
eyespider
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Java Black
anyone have a part number?
On my bmw I change this every service, is this the same on the RAnge Rover Sport TDv8?
Post #517902 Wed Feb 15 2017 6:53pm
Not aware that this is a usual service item. 2012 SDV6 - it's missing a couple of cylinders
Post #517911 Wed Feb 15 2017 9:11pm
Slowpoke Disco
Australia 2008 Range Rover Sport TDV8 S Stornoway Grey
did you ever get this sorted? My car is doing the exact same thing, minus the vapour out the dipstick, but that could be because of the warm climate where I live.
Post #608143 Mon Jan 04 2021 12:39pm
dannyvee
Australia
Reviving old thread, shakeapaw, Slowpoke Disco, anyone else - did you find the cause of this?
Thanks,
Post #630868 Thu Feb 16 2023 4:35am
Slowpoke Disco
I did for mine. Apparently it was an internal crack in one of the intake manifolds. I replaced the one on the right (RHD car) myself and then got told by the local specialist that now that one was done there was going to be additional air pressure going into the left side manifold because of no internal leakage of compressed air. So I paid for them to replace the left side manifold because the air con needed to be degassed and with 2 new manifolds it has been fine since, touch wood. I never found out whether it was the left or the right manifold but perhaps some break more than others. Good luck. And ask for a pressure test on the manifold once it's removed, just so you know it definitely was the cause of the issue.
Matt
Post #630869 Thu Feb 16 2023 7:20am
dannyvee
Australia
Thanks Matt, good to know.
I guess PCV valve would be a "good outcome", and it could be worse then a pair of manifolds, but still would be a chunk of time & money to fix.
Cheers,
Post #630873 Thu Feb 16 2023 9:33am
Slowpoke Disco
I would have loved it only be a PCV issue , that would have saved me 3 nights of reasonably tricky labour and $1000 for the rocker/intake manifold for one side. Try calling Triumph Rover in Adelaide for some advice if you have an issues as they're the ones that did my left side manifold, and at the same time replaced the thermostat housing, blanked the EGR, full service and filters and did a performance tune. Not cheap but they know their stuff. So a total of $5500 and it transformed the car and gave me enough confidence to use it on many long highway drives.
Post #630874 Thu Feb 16 2023 10:09am
