![]() | Home > General (L494) > Low battery warnings... - Advice required please... |
| Farmer Chalk Member Since: 02 May 2015 Location: London Posts: 556 |
Well today not a happy bunny! .....
| philmw Member Since: 18 Aug 2006 Location: Nottingham Posts: 1691
Sorry to hear this, and hope they find the problem.
As suspected... fabulous chap from Assist who attended... apparently there is a 0.3 amp drain on the battery somewhere...they need to rule out the non OEM equipment before they can do anything...he is suspecting the Cat 5 Tracker...
No, time for a charge. |
My last FFRR and my first Evoque both had Trakker trackers and LR was adamant that that was what was causing my battery problems with both cars. The Evqoue was so bad that it would kill the battery like yours in a couple of days. As I was abroad and it was my father who found the car completely dead after managing to open a door but then not being able to lock it again, he contacted me and I told him to call LRA and tell them to keep the car in the local dealers as long as they needed it to resolve the issue. The car was in the workshop for a month (I didn't need it and at least it was secure there!) for tests and visits from techs from the Warwick/ Gaydon technical division of JLR. They found that it categorically was not the aftermarket tracker that was causing the problem it was something in the Battery Management System that they had not been able to replicate in any car at the works. They solved the issue and after a new update to the BMS software and fitting an AGM battery to the car I never had another isssue with the battery discharging and had confidence that I could leave it up to 90 days without running it. One thing that they did do at my request (and only on that one car) was to re-enable the front power socket so that I could keep my solar panel trickle charger plugged and keep the battery topped up, no other Evoque before or after has had the power sockets live when the ignition was off. The fix worked a treat. Since then my 2nd Evoque had no issues the retaining charge and neither has my RRS. The first Evoque was one of the very first off the production line in 2011, the 2nd was a 2014MY car and my RRS is a 2015MY. I don't know what year yours is but if it is a 2013MY or early 2014 it may be that it needs a BMS tweek or an AGM battery fitting. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Tim mine is a twin of yours, almost the same specs and an October 14 reg so on a 64 plate... it's a few hundred back from the 15 model year and so I can't update the battery module software.... Tracker are going to see the car this week and hopefully give it a clean bill of health....then off to do battle with the dealer on the 22nd! |
| muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5644
I had low battery issues with MY10/MY13 RRS and MY16 DS - used to drive me mad |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159
If your RRS is driven for short hops rather than decent journeys then it will drain the battery. Mine does 1-1.5 hours each way commutes each day and stays at / close to 12.75V. Yesterday I popped to the shops so it did 3 miles each way after remotely running the FBH for half an hour. Showed 12.6V this morning. Do that regularly without long drives and the battery will drain. These things have a thirst for fuel and a hunger for volts. 2012 SDV6 - it's missing a couple of cylinders
| udash Member Since: 16 Oct 2009 Location: manchester Posts: 196
Smaller battery is not connected to the main battery directly, and its connection to charging and electric loads are controlled by the BMS, battery management system. |
My only journeys I do in it are normally a minimum of 60-70 miles on my commute to the office circumventing the M25... the primary fault occurred 2 hours after a drive to Birmingham from deepest darkest Kent ...... Goodness knows what drained that amount of power....I would expect leaving the headlights full on wouldn't have drained the battery that quick.... Tracker have been brilliant and after contacting today they are coming down Thursday to determine its not their equipment! Good service! Will keep you all posted! |
| kmpowell Member Since: 23 Oct 2016 Location: UK Posts: 259 |
Does your MY apply to the "Q634 - Gateway Module Stay Awake - Battery Drain" software update recall that was started by Lanr Rover before Xmas?
Unfortunately not!
| PauloAmore Member Since: 27 Jan 2007 Location: Bonnie Scotland Posts: 1293
So...
| matsoutback Member Since: 13 Jul 2016 Location: Queensland Posts: 152
Landrover sell a battery charging kit, hard wired directly to the battery.
| All times are GMT |
