Home > Technical > Rear ACE Bar Leaking
Andi2707
United Kingdom 2009 Range Rover Sport TDV6 HSE Santorini Black
Hey guys.
My 09 RRS has been diagnosed with a "slight" leak of the rear ACE bar.
From my research on here, its approx £1600 to replace.
Does anyone know if this is leak would be subject to an MOT fail?
I have only had the car for 11 weeks & in that time it has had the hand brake module, rear pads and discs and rear ARB bushes changed under warranty. I'm hoping that this too will be covered, but in the event its not, im wondering how important it really is.
As always, any advice would be greatly received!
Post #517596 Mon Feb 13 2017 11:22am
Pufftmw
Dunno about MOT fail but you can buy the same rear ACE from a place in Wimbledon for about £790 - have a look on eBay.
I was then charged 5 hours labour (£460) to have it fitted by LRR in Charlton.
I trust that your garage didn't replace the rear ARBs already? They come with the kit. If you were under warranty for them, then surely you would be under warranty for this as well?
Post #517610 Mon Feb 13 2017 12:38pm
Andi2707
Hey Pufftmw....Well they did actually change the rear ARB bushes a few weeks a go under warranty but didn't mention the leak on the rear ACE bar. Not surprising really that they weren't forthcoming with any other issues on the car, so i took it to a local Land Rover specialist who gave the car a health check which is where it was spotted as the fluid level in the bar was <min.
Thanks for the heads-up about ebay tho, appreciate it.
Post #517645 Mon Feb 13 2017 4:09pm
Socast
How long have you owned the car ?
If they repaced the bushes under warranty they are almost certainly liable for the sway bar itself... Get back to them and make sure they do it. Thumbs Up
Post #517665 Mon Feb 13 2017 5:40pm
maybe they disturbed it, and now its leaking
Post #517681 Mon Feb 13 2017 7:01pm
ShooterNeil
England 2007 Range Rover Sport TDV8 HSE Java Black
Mine started to leak then after buying a new ACE bar it just stopped lol so now it's just sitting in the garage waiting hope I neve have to use it 61 AB 5.0 supercharged rocket
07 HSE TDV8 with lots of toys EGR removed BAS remap
56 HSE WAS FULL OF PROBLEMS
Post #517692 Mon Feb 13 2017 8:43pm
Jaggs
It's not stopped it's just run out of fluid Wink Rolling with laughter Nanocom Evo
Post #517699 Mon Feb 13 2017 9:44pm
ShooterNeil
Rolling with laughter no no no I looked it's half way between the marks it never moved much at all when leaking just the odd drip on the drive oncevever 2 days 61 AB 5.0 supercharged rocket
Post #517710 Mon Feb 13 2017 10:30pm
Danv8
United Kingdom 2009 Range Rover Sport TDV6 HSE Lux Alaska White
Re: Rear ACE Bar Leaking
Andi2707 wrote:
Hey guys.
Yes it is an mot failure, My front one was leaking with clear signs of fluid loss, it failed the mot and was replaced, now 2 years latter my rear has signs of oil vapour which the mot guys noticed but said had it actually had oil droplets on it, they would of failed it.
Post #517721 Tue Feb 14 2017 8:25am
Andi2707
many thanks for the advice and updates guys...having only had the car for 8 weeks , im hoping that garage does replace this under warranty.
Post #517735 Tue Feb 14 2017 10:43am
