![]() | Home > In Car Electronics > Where's the Mute button? |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5116 ![]() ![]() ![]() |
Not one.
If you press the 'C' button at the bottom right of the headunit it shuts off the Traffic Info that is coming over the FM from a station other than the one you are listening to but only until the next broadcast.
Bill Portland Member Since: 01 Feb 2017 Location: Dorsetshire Posts: 395 ![]() ![]() ![]() |
'C' button? I don't seem to have one of those either. |
fdhadi Member Since: 17 Feb 2015 Location: Wigan Posts: 180 ![]() ![]() ![]() |
Not sure if it's the same thing but pressing the Audio button cuts off the current traffic announcement and reverts back to whatever Audio you are listening to. |
I'll try that on the morning commute. Cheers! |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1559 ![]() ![]() ![]() |
On mine the info button (bottom left of head unit) turns traffic announcements off if you push it once whilst that info is being broadcast but it will still allow the subsequent traffic broadcast to come through. Push it twice if you want to turn traffic announcements off whilst they are being broadcast (or once if no traffic info is being broadcast).
Yep, that works for the traffic announcements (although it does switch the screen to the audio/video mode, obviously. Any way to cut off the sat nav direction announcements other than permanently? |
You were right, everything has changed since 2008 and mine! I don't get the "loudspeaker with a line through it bottom right of the nav screen" but I do get a "repeat last announcement button" |
