![]() | Home > Technical > Judder at low revs |
Highly rated but not sure if they do flushes http://www.bristoltransmissions.co.uk/home/
Miller Member Since: 05 May 2015 Location: Trowbridge Posts: 8 ![]() ![]() ![]() |
Thank you will email Bristol transmission |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4501 ![]() ![]() ![]() |
If you have a judder, a flush will not cure it permanently. It may cure it for a few thousand miles, but it will come back
It's only does about 3000 miles a year , so will try the flush first as may be good for another 2 years |
TheWojtek Member Since: 08 May 2015 Location: PoznaĆ, Poland Posts: 737 ![]() ![]() ![]() |
Or next 30 miles, should your TC decide not to collaborate anymore. If it judders, it's one serious kickdown away from failing. Regards etc.,
erickwan Member Since: 27 Mar 2016 Location: P Jaya Posts: 140 ![]() ![]() |
Had this as well, except it shuddered a little less when warm. Used Shudder Fixx and it's been good for the last 25,000 kms, touch wood. |
