Home > General > STUPID QUESTION ALERT ;-) Do I have ARC?
rdr
Just wondering if there is a way of telling if my 2005 RRS has ARC or not? Need to have rear anti roll bar D bushes replaced, and garage has asked if car has ARC - hundred of pounds more if it has ARC apparently.
Thanks in advance
Post #516964 Tue Feb 07 2017 10:07am
nigethecat
Scotland 2008 Range Rover Sport TDV8 HSE Java Black
Have you tried phoning your local LR Dealer, giving them your VIN and asking them which bushes you need ? I did that with mine just to make sure - the easy option for us non-techy people !
Post #516967 Tue Feb 07 2017 10:27am
d-9
The local dealer was surprisingly helpful when I called up and said 'will this part no fit my car'. It turns out they were probably wrong, but they were helpful!
Post #516972 Tue Feb 07 2017 11:27am
It would help if you filled in your profile for you car details
If it's a 2.7 diesel the answer is probably NO.
If its a 4.2 SC petrol the answer would be YES
Post #516976 Tue Feb 07 2017 12:02pm
Jaggs
My 2.7 does, is there a reservoir with a yellow cap behind divers headlamp? If so its fitted, shouldn't be hundereds more for bushes though, a little more awkward but not to that degree Nanocom Evo
Post #517003 Tue Feb 07 2017 4:07pm
Tim in Scotland
It was an option on HSE 2.7's from launch standard on the 4.2 and 4.4 V8's - official name was Dynamic Response and it has other benefits than just tightening handling on road as it allowed 2005/2006 MY RRS to run 20" wheels without nullifying their warranty as it included the necessary uprated steering rack. It also does some nice tricks off-road that most owners will never benefit from on road, like it can automatically disengage the rear anti-roll bars for greater wheel articulation and then relocate them and it can allow one wheel to "reach" down a further 10cms than normal in an attempt to find hard ground to direct the power to............. which is one thing a Disco3 cannot do as DR was never offered on Disco3 and it makes RRS actually a very slightly better car off-road..........dons anorak and closes door............ 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #517006 Tue Feb 07 2017 4:35pm
rdr
Clever people on every forum Wink
Post #517030 Tue Feb 07 2017 8:16pm
rdr
Thanks a lot Jaggs, will have a look in morning. They seem to think 7 hours with, up to 2 without, and their labour rate is not exactly cheap.
Appreciate it..
R
Post #517031 Tue Feb 07 2017 8:18pm
rdr
Thanks Tim, that's handy to know - although I hope mine doesn't have it Wink All the best
Post #517032 Tue Feb 07 2017 8:20pm
Dynamic Response applies to both ends, not just the rear end and allows both ends to behave as if they are not fitted with anti roll bars off road. On road it gives better roll control than standard bars.
As for bush replacement costs, there shouldn't be a huge difference between the two systems. Certainly not over one hundred pounds. 2012 SDV6 - it's missing a couple of cylinders
Post #517057 Tue Feb 07 2017 11:08pm
