Home > Maintenance & Modifications > Random battery light
Gilly1
Hi all, my battery light has started to come on and go off randomly, had brand new battery approx 3 months ago, checked battery and alternator with volt meter & both SEEM to be ok, battery holds charge when car off and alternator puts out good input when running even with every electric on. I presume it's loose connections, battery or alternator, just asking in case there could be another cause I could/should check as well knowing the sport is very strange sometimes. Ha.
Post #516843 Sun Feb 05 2017 11:39am
Bodsy
Site Sponsor
Remove the charging circuit fuse and check it, check the alternator connector.
What actual voltage are you getting? Engine off and then when engine running. Rather than just good. Thumbs Up
What voltage are you getting when the battery light comes on?
I'd say that it's the beginning of your alternator giving up, but could also be an Earth issue perhaps. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #516844 Sun Feb 05 2017 11:43am
Gilly1
Hi bodsy 👍 Is the charging fuse the one on positive battery lead by connector, if I remember correct it was 12.3v after leaving over night and checking in morning, and 14.3v min and 14.7v max when running and playing with heater/lights/etc, didn't actually think of checking when light was on, good idea Idea makes sense now you said it, ha, Embarassed will check later, knowing the sport it won't come on now I want it too. Whistle
Post #516847 Sun Feb 05 2017 12:09pm
scrumps
Gilly,
I just had LRA out to my L494 with a charging system fault.
Turned out to be a loose battery earth lead ( at the body end).
Might be worth a check.
Scrumps. Somerset - Where the apples do grow and the cider do flow!
2021 Defender 90 D250 HSE in Tasman with white roof.
24MY D300 AB - Verasine Blue - 😀
19MY SDV6 AB - Byron Blue - Gone
17MY D5 SDV6 HSE - Firenze Red - Gone
16MY SDV6 AB -Aruba Silver - Gone
13.5MY SDV6 "HSE Black" - Baltic Blue - Gone
10MY TDV8 HSE Galway Green - Gone
14MY D4 HSE in Scotia Grey - Gone
05 TD5 D90 CSW in Cairns Blue
Post #516927 Mon Feb 06 2017 8:09pm
Gilly1
Hi scrumps, thankyou kindly for your message, I'm working away all week but when I get bk will be giving all a good check over the weekend. Will def be starting with loose connections. Hopefully will be lucky. Very Happy Thumbs Up
Post #516931 Mon Feb 06 2017 8:26pm
Gilly1
Took the sport for a drive today and airbag light came on as well as battery light, then window washers stopped working all other wiper functions worked ok ( auto on, manual speeds all ok,) then all suspension sensor indicators on 4x4 screen went red, they cleared after switched off then on again. So got home and checked volts with meter and battery was 12.3v with engine off and 12.5v with engine on went up to 13v when revved, so think it's new alternator time and fingers crossed it will clear the other faults.
Post #517417 Sat Feb 11 2017 2:59pm
Gilly1
Hi, can anyone please confirm this is correct for my 2006 sport 2.7TDV6 please, (BIT CONFUSED if I've got ACE)
https://www.jgs4x4.co.uk/land-rover-range-...00-dan987/
Post #517425 Sat Feb 11 2017 4:51pm
doubt you have ACE.
You will have a bottle with yellow cap by the airbox, at the front, on the drivers side if you do
Post #517426 Sat Feb 11 2017 4:54pm
Gilly1
This one you mean mate.
Post #517427 Sat Feb 11 2017 4:58pm
yeap, ok you do have ACE then.
Post #517428 Sat Feb 11 2017 5:03pm
Gilly1
Lol, thanks mate, do you no best place for alternator.
Post #517429 Sat Feb 11 2017 5:04pm
not really.
http://www.advancedfactors.co.uk/alternator--fixings-1627-c.asp
£192
Post #517431 Sat Feb 11 2017 5:10pm
DrRob
Advanced Factors are site sponsors and there is a discount code somewhere....
http://www.rrsport.co.uk/forum/topic42096.html
A knackered alternator usually takes the battery out with it when it gives up so get it swapped asap Thumbs Up Visitor from fullfatrr.com
Post #517432 Sat Feb 11 2017 5:28pm
Gilly1
Will do, that's great, thanks, (got to love a discount code Thumbs Up )
Post #517444 Sat Feb 11 2017 7:05pm
