Home > Technical > Definitive answer required
Cpt Jack Sparrow
Wales 2013 Range Rover Sport SDV6 HSE Fuji White
Hi all
getting a little muddled trying to get a definitive answer on my issue. many internet search have just confused me more
I have a 2006 4.4 V8 SE RRS.
the headlight washer are not squirting.
I know the lights have to be on. I know its every 3 uses of the windscreen washer and I know there is fluid in the tank.
The answer I can't get is.. are the headlight washers on a separate fuse? if so where is it?
any other thought on the non functioning would be appreciated.
Thanks
Paul Thumbs Up
Post #516923 Mon Feb 06 2017 7:45pm
I think it works for the first spray with the lights on.
seperate pump, fuse, relay
Post #516932 Mon Feb 06 2017 8:31pm
Fuse 7 in engine bay. 30A
Post #516937 Mon Feb 06 2017 8:37pm
Cpt Jack Sparrow
thanks, I'll check that one in the morning
Post #516939 Mon Feb 06 2017 9:24pm
Socast
The headlight washer is on a seperate pump (the two pumps are integrated into a single unit), it's a fairly regular thing that the headlight pump gives up due to not being used.
A new pump isn't that expensive and is very easy to fit, you need to remove the front bumper to do it, so with your car being a 2006 it night be worth replacing the wiring loom for the parking sensors while you're at it (again, not an expensive part) Thumbs Up
Post #516956 Tue Feb 07 2017 9:34am
Cpt Jack Sparrow
Thanks I'll source a pump after trying the fuse. But I'm guessing if they are in the same unit, both would fail if the fuse blows
Post #516958 Tue Feb 07 2017 10:32am
Socast
Sorry, I did the pump on the second car the other week and confused myself.
The pump for the headlights is stand alone. You have a second pump that feeds the front and rear washers.
But it's still a cheap part and easy to replace.
Post #516961 Tue Feb 07 2017 10:48am
Cpt Jack Sparrow
Can confirm its not the fuse.
Front end removal coming this weekend.. Rolling Eyes
Post #516971 Tue Feb 07 2017 12:20pm
Cpt Jack Sparrow
bit premature but got stuck in
the pump was seized solid with rust, ordered a new one for £33, will be here tomorrow
hopefully all resolved and working by this time tomorrow.
thanks for the help[ and advise
Paul
Post #516998 Tue Feb 07 2017 3:42pm
Cpt Jack Sparrow
Pump replaced today, I am now able to spray my headlights all working well, and really good pressure Thumbs Up Thumbs Up
Post #517144 Wed Feb 08 2017 7:51pm
fdhadi
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Result Paul, well done Thumbs Up
Post #517187 Wed Feb 08 2017 11:34pm
CANROVER
Canada 2010 Range Rover Sport Supercharged Santorini Black
Hey Paul where did you order the pump from??? Can you please post the link to the exact pump you bought and the site you bought it from?
On mine I know the pump squirts onto the headlights on the first squirt and then does it again after 10 minutes.... It's in the manual somewhere.
Post #517513 Sun Feb 12 2017 2:25pm
Cpt Jack Sparrow
I rang my local Land Rover dealer, and collected the following morning. Thumbs Up
Paul
Post #517556 Sun Feb 12 2017 9:10pm
