![]() | Home > Maintenance & Modifications > eBay side steps |
mrfixit Member Since: 23 Dec 2010 Location: Bolton Posts: 705 ![]() ![]() |
My experience is,they eBay steps are great value,fit perfectly but the aluminium does tarnish very quickly.I had genuine steps on my first sport and that aluminium tarnished as well but the metal did seem better quality.
Smarttech Member Since: 11 Jan 2017 Location: West Sussex Posts: 424 ![]() ![]() |
I see for a little bit more you can buy them with sill protectors. Is it worth the extra or are these just traps for wet road dirt to sit in ? |
wings21660 Member Since: 11 Feb 2015 Location: Gretna Posts: 65 ![]() ![]() ![]() |
I got mine of fleabay for my last rrs they were easy to fit but did discolour along the aluminium strip. If you do buy some make sure you strenghten the strips before you bolt them to the car they are well known for popping off when the rivets rust, I had to re-drill both sides it would have been easier off the car, hope this helps mate |
Strengthen the strips ? What part are you n about when you say strips |
There is an aluminium strip goes from top to bottom held on by rivets that rust, Ive just had a look on ebay the first set I come to shows them quite clearly |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2796 ![]() ![]() |
Side steps can be purchased with either precut - none cut or no replacement sill protectors at all. You need to remove your current sill protectors as part of the step installation.
As Peachy say's,,def get the ones that's pre-cut.It took he half hour a side working on the floor with suspension raised.
I got mine with pre-cut sills for about 120 delivered next day.Only other bit of advice I would offer is to get yourself an 8mm tap to run through the holes before you try and get the bolts in. |
d-9 Member Since: 10 Jan 2017 Location: Wiltshire Posts: 321 ![]() ![]() ![]() |
Got a link to where you got them from? |
That was the seller carvantruck2010 |
Cheers Peachy for the link, your a star. Will find some with the sills ready cut and get some ordered ready for when I can collect the car from the dealership next week. |
Thanks mrfixit |
Which eBay seller did you buy them from ? |
Cheers Bright blue |
