![]() | Home > Maintenance & Modifications > Flat battery after holiday away |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5070 ![]() ![]() ![]() |
They don't like being left.
Pakolainen Member Since: 14 Mar 2016 Location: Helsinki Posts: 310 ![]() ![]() ![]() |
I concur on the CTEK chargers, i've just bought a new battery. 2 weeks later i bought the CTEK and plugged it in after not using the car for 2 days and it showed the battery was ½ full. An overnight trickle charge and it was 100% in the morning.
jamesbilluk Member Since: 28 Jun 2016 Location: Worcester Posts: 23 ![]() |
Thanks guys |
In fairness CTEK's always find something to do! (in the need to charge the battery).
You will need a decent sized solar unit.
Many thanks Andy,
We like the CTEK 5 around here (with red button)
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9081 ![]() ![]() ![]() |
If the OP's battery was the original fitment then it was probably ready for a change anyway. Be worth getting the alternator output checked too. 2012 SDV6 - it's missing a couple of cylinders
d-9 Member Since: 10 Jan 2017 Location: Wiltshire Posts: 322 ![]() ![]() ![]() |
The screw on indicator leads are really useful because it saves you removing the battery cover everytime you want to put the car on charge. |
Gornal Hills Member Since: 10 Nov 2014 Location: Dudley Posts: 380 ![]() ![]() ![]() |
Hi, ours does not get much use really, but i do find a overnight trickle works wonders once a week, especially over the winter months |
