![]() | Home > In Car Electronics > 1.8amp permanent Battery drain problem. MY2012 RRS SDV6 HSE |
I would say with that amount of current draw it is probably the alternator that is at fault, it might be showing good charge voltage, but leaking inside from a burnt out diode or short in the regulator.
Cheers Flack, both the LR Assist engineer and the LR dealership @ Pickering both checked the Alternator and both said it was working fine. When I take it in to the Indi garage, I will get them to thoroughly check as you have suggested. Thanks. |
Orange RRS Member Since: 24 May 2016 Location: Lincolnshire Posts: 89 ![]() ![]() ![]() |
Is the current draw being measured after the car has been locked for at least 6 minutes. You have to trick the car in to thinking the bonnet is shut or it will not go to sleep properly. The current draw should gradually decrease as the car goes through its closing down process.
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2021 ![]() ![]() |
Hope you get it sorted soon....frustrating |
nick@lh Member Since: 18 Jun 2016 Location: York Posts: 1 ![]() ![]() ![]() |
Keep me posted on this Johnski. I'm based at Snainton I was going to drop my 2011 Range Rover Sport HSE in to Hatfields in Pickering in the morning with exactly the same problem! I only use the car on weekends and it is always flat. |
