Home > General > Any shortcuts on the following repairs?
W44NNE
United Kingdom 2005 Range Rover Sport Supercharged HSE Java Black
My car has been in with a Land Rover specialist today. Really helpful and friendly, but I'm just hoping to avoid some costs if at all possible.
Here's what needs doing. The fluid changes are a request of my own rather than a recommendation. I doubt they've ever been done and I want peace of mind as I use the car every day.
- Parking brake module needs replacing as it's failed - £977
- Rear parking sensors were working, fronts never have in my ownership. The rears stopped recently as well anyway, so the specialist has recommended replacing both harnesses in the hope that they're faulty. There's a "short to ground" at both ends - Around £130 per end including new harness and labour
- Headlight washer pump needs replacing. I can't remember the cost for this but won't be terrible and they'll do it at the same time as replacing the front sensor harness
- Transmission fluid change with new, upgraded sump - £477
- Front and rear diff oil change at around £110 including labour
Are there any ways I could look to save money on this? Let's just say it's not ideal for me right now lol. I'm not afraid to get my hands dirty but I'm not mechanically minded.
Post #515582 Mon Jan 23 2017 7:32pm
crocs
Scotland 2011 Range Rover Sport 3.0 TDV6 HSE Ipanema Sand
My advice?
Ditch the parking brake module. Who ever uses the parking brake on an automatic? But will be needed for its next MOT?
Robert
Post #515585 Mon Jan 23 2017 7:39pm
W44NNE
Yeah I've been using park with no issues anyway, but it will need it in the future of course so I may as well get it done; although perhaps not at this moment in time with all the other things being more pressing IMO.
Post #515587 Mon Jan 23 2017 7:40pm
Time to get into DIY !
Well when it warms up, in March?
I would do the gearbox change yourself. Don't change the filter, pump all the oil out the front. Can be done for less than £100.
Do the diffs yourself for about £28. It's not urgent.
I would add the transfer box to the list, £60? if you do yourself.
What milage is on it ?
Post #515588 Mon Jan 23 2017 7:44pm
PEACHY
Shocked Parking brake module has been known to be repaired but replacement should be no where near that price Shocked parking sensors eventually fail - they are battered by the elements day in day out - usually the front. If fault codes was read & they have identified the sensors this can be a DIY job if it is the looms - again another DIY job.
I can't comment on fluid changes but Bodsy or Disco Mikey will give you more advice on those issues. I would hold fire for a bit Thumbs Up 16MY Estoril Blue SVR.............
Post #515589 Mon Jan 23 2017 7:45pm
PEACHY
Wayne - change your profile to show other forum members the RRS you are driving Thumbs Up 16MY Estoril Blue SVR.............
Post #515590 Mon Jan 23 2017 7:52pm
Disco_Mikey
Re: Any shortcuts on the following repairs?
Module is about right if it needs replaced, along with new shoes/discs/pads etc. Though we don't know why it needs replaced. They can be unjammed internally
PDC fault is most likely a sensor short circuited internally. Logs the same fault code for front + rear, even if only 1 sensor is at fault
Takes 15 mins to replace, with or without the bumper on
Sump is a little pricey. I charge £350
Diff oils are a little pricey also, but not hugely so
Post #515591 Mon Jan 23 2017 8:02pm
Jaggs
Depending on age / mileage of your RRS consider a warranty, they aren't cheap to maintain and something like the handbrake module may have been covered had you been covered, doesn't help with preventative / service items though. Nanocom Evo
Post #515592 Mon Jan 23 2017 8:10pm
DrRob
Drive it to Dundee and let Mikey sort it Thumbs Up Visitor from fullfatrr.com
Post #515601 Mon Jan 23 2017 8:59pm
mrfixit
2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Try Mick(Flack)he knows his way around. Thumbs Up
Post #515602 Mon Jan 23 2017 9:03pm
W44NNE
Thanks for all the replies. Some great advice as always.
The module replacement at £977 is actually without any discs or pads etc. I'd love to bring it up to you Mikey but it would cost in the region of £200 just in fuel, plus a hotel etc which would negate any saving really.
Your prices sound fantastic though; just a shame we're so far away.
Post #515615 Mon Jan 23 2017 10:42pm
W44NNE
Sorted, after resizing the image about 14 times until it met the requirements Laughing
Post #515617 Mon Jan 23 2017 10:52pm
mrfixit
Mick is NW,Preston"ish
Post #515618 Mon Jan 23 2017 11:03pm
W44NNE
Thanks I've PM'd him
Post #515619 Mon Jan 23 2017 11:09pm
Lonescout
2006 Range Rover Sport TDV6 HSE Cairns Blue
For those who consider just using Park on their transmission as the 'handbrake', a little understanding of the mechanics involved may be enlightening.
http://myautomatictransmission.com/transmission-parking-pawl.htm
Post #515621 Mon Jan 23 2017 11:12pm
