Home > In Car Electronics > Parking aid/reverse camera unavailable?
My RRS1 has this speaker in the rear.
http://www.ebay.co.uk/itm/LR-RANGE-ROVER-S...SwVFlT~2gj
Post #515544 Mon Jan 23 2017 1:46pm
abilover
England 2012 Range Rover Sport SDV6 HSE Fuji White
Exactly what I thought.
My symptoms are still the same. Which is the front sounder makes a noise on startup, which could mean the rear sounder is faulty
But I can't find it Big Cry
Post #515546 Mon Jan 23 2017 2:23pm
Not sure if it is of any relavance but on my MY13 RRS 1 the sound from the Rear Parking Sensors actualy come from the Rear Door Speakers on both sides.
Post #515607 Mon Jan 23 2017 10:03pm
Yes that does help.
And and advantage is you can change the volume somehow.
Post #515611 Mon Jan 23 2017 10:16pm
I know you can adjust phone, satnav volume etc. through the menu but not sure if parking sensor volume is in there, will have a look later.
Post #515612 Mon Jan 23 2017 10:26pm
abilover
The plot thickens!
Great piece of information there.
According to that diagnosis I posted earlier, it says that "if there is a beep from the front sounder, there could be a fault with the rear sounder?" But that can't be so when the system uses the rear speakers?
I think that this only refers to the earlier cars where there is a sounder next to the module behind the NSR trim panel.
At least I'm not going mad Bow down
Still can't seem to diagnose it though! main dealer beckons Crying or Very sad
Post #515616 Mon Jan 23 2017 10:48pm
abilover
Just thought I'd post and draw a line under this fault, to possibly help someone else.
I got hold of a local guy who specialises in LR diagnostics, but he only came up with the same fault code that I already had.
He checked on Topix and emailed LR for me and they narrowed it down to 3 possible faults
1. Wiring harness continuity between the Module and the switch
2. Switch fault
3. Module fault
Checked the continuity all ok
Bought a new switch panel and fitted that, fault still there. Bought a new Module and reset, all working again.
So there you go, a new Module at a cost of £128 + vat and it's all good again.
Thanks for your help guys Thumbs Up
Post #516813 Sat Feb 04 2017 11:44pm
kansanbrit
United States 2011 Range Rover Sport Supercharged Zambezi Silver
I know this an old post but I had this display shown on a car I bought. I tracked it down to a bad parking sensor on the front bumper. Apparently any faulty sensor front or back will stop the camera working. I also noticed that as my battery ran down while messing with the car with the ignition on it stopped working again although the parking warnings were still working which they weren't initially. As soon as I drove the car and got the battery charged up it started working again, so it is quite voltage sensitive.
Post #599502 Mon Jun 01 2020 9:04pm
pomistea
Ireland 2013 Range Rover Sport 3.0 TDV6 HSE Fuji White
If you unplug a rear parking sensor, will the camera and sensor system stop working?
Post #630881 Thu Feb 16 2023 2:07pm
pomistea
For hopefully someone else’s benefit.
1. If a single sensor is defective the entire parking / reverse camera system shuts off.
2. If a single sensor is plugged out, the system also shuts off
3. LR wanted over £100 for a new sensor, Amazon wanted £16.22
https://www.amazon.co.uk/dp/B08N5T1L8Q?ref=ppx_pop_mob_ap_share
Post #630933 Sat Feb 18 2023 11:31pm
Barry webb
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Sumatra Black
Thank you for putting this info on the forum I've had the rear camera problem for over 0ne and a half years I've replaced the camera but it's still not working.
I didn't think of the bumper sensors so maybe that's my problem all along.
Post #633499 Thu Jun 01 2023 11:08am
Crraigymmmmm
United Kingdom 2012 Range Rover Sport 3.0 TDV6 Autobiography Orkney Grey
It could be any one of the 8 sensors that takes the system out, in my case it was a wire in the loom to the front inner left so I can a new cable and the system was back online.
The fault code was identifying the inner sensor so I cont checked the 2 cables to the parking module and found an open link.
Post #633500 Thu Jun 01 2023 11:17am
