![]() | Home > General > New Owner - list of questions! |
ilard Member Since: 20 Aug 2010 Location: London Posts: 975 ![]() ![]() |
Congratulations on the new motor. I have a MY 2011 poor-man's diesel, so I can answer some of these.
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 ![]() ![]() ![]() |
The pre-facelift RRS had this smart shortcut of "touch anywhere on the map → select 'Home' icon", perhaps your satnav still retains it? Regards etc., Wojtek --- WAS: 2006 RRS Supercharged IS: 2010 RRS TDV8 HSE |
In Stored Locations add the home address and then you can press to talk and say "NAVIGATION GO HOME". I do not use this feature. Manually it would be Menu > Destination Entry > Home.
crocs Member Since: 22 Jan 2017 Location: Ayrshire Posts: 115 ![]() ![]() ![]() |
'Navigation, go Home' works for me. It's really useful if you'in an unfamiliar city centre, otherwise you'll probably know the way home.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5089 ![]() ![]() ![]() |
It is posible to buy just the front perspex part from L/R and easy to change, however you will need to remove the instrument cluster to do it which can be a bit fiddly, easiest way is to remove steering wheel first. Cheers Col |
Lunar_Lamp Member Since: 14 Jan 2017 Location: UK Posts: 9 ![]() ![]() |
Ah, thanks Col - this sounds like it's an irritating job to do, but may well be worth it for me.
I'll dig the part number out later and add to post for you, just enjoying 30 degree sunshine on the beach at the moment. |
Part Number: LR041042 retails around £85.00 with vat. expensive bit of plastic, but inline with L/R rip off prices.
Thanks for that Col!
