Home > In Car Electronics > ACM Installation
nigethecat
Scotland 2008 Range Rover Sport TDV8 HSE Java Black
Aaah... that might explain it, mine has the full B/T and electric steering column, hopefully that means it will be pre-wired for the heated steering wheel too!
many thanks
Post #514247 Thu Jan 12 2017 4:12pm
Tim in Scotland
IIRC you will need to buy a new steering wheel (with the switch for the heater) and a different clockspring before you can fit a heated steering wheel. I would like to fit one to my current RRS as it is the first since 2007 that I have had a car without being able to toast my fingers on a cold morning..... 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #514261 Thu Jan 12 2017 6:08pm
d-9
Does anyone know if the older ACM with the cradle will work with newer iPhones like the 4s, 5/5s/7 (with a lightning to 30pin adaptor)?
Post #514870 Wed Jan 18 2017 10:56am
nigethecat
Should do but you can always try one of these: http://www.ebay.co.uk/itm/291842062469?_tr...EBIDX%3AIT
That was my plan, rather than use the cradle, just run this cable into the glove box...
Post #514873 Wed Jan 18 2017 11:20am
