Home > General > What should I have checked out on a 2005 RRS?
W44NNE
United Kingdom 2005 Range Rover Sport Supercharged HSE Java Black
I recently purchased a 2005 4.2 Supercharged RRS. It needs a few things attending to which I already know about, but what are the main things I should have looked at? It's booked in at a specialist but I want to make sure they look at the right things.
I'm thinking things like oils etc, which I'll probably get the diff and gearbox oil replaced anyway. Is there a timing belt, and do the supercharger pullies need replacement at any point as well?
Any advice would be appreciated.
Post #514562 Sun Jan 15 2017 4:24pm
The engine is chain driven.
Where are the pics Wink
Post #514572 Sun Jan 15 2017 5:31pm
W44NNE
Glad to hear that. Are chains likely to last the life of the engine?
No pics yet but will post some soon Smile
Post #514575 Sun Jan 15 2017 5:40pm
Yeah I think they sorted out any chain and tensioner problems by 2005.
I would clean out your rear wheel arches of mud and apply some anti rust stuff.
Post #514580 Sun Jan 15 2017 5:54pm
Tim in Scotland
Other than mechanicals get them to check that the lock for the upper section of the tailgate isn't corroded - it is common for water to get in either as condensation between the plastic skins or through a perished rubber cover for the press button - it causes corrosion on the mechanism and it won't release. Check that the transfer mecjhanism between high range and low range gearboxes is working - recommendation from LR is to change to Low Range and back monthly to exercise the mechanism, 99% of owners don't do it and then find that when they want to use the low range gear box the mechanism is seized up. It is not a complex or expensive thing to fix but worth checking - you can try it yourself by selecting N on the gear selector and pressing the Hi/Lo range button, the change over should be quick and almost silent, you will get a warming light on the dash when it has completed the change over, return to High range should be just as quick and smooth and the indicator light should go out on completion. I would suggest that even if you never intend to go off reading you should perform this simple action monthly. As I use my RRS off-road the low range gets operated most months anyway but if I haven't used it off-road in the previous month it only takes 2 minutes to operate it..
Also get them to check that all outstanding recalls and TSB's are updated if it hasn't been into a main dealers for a few years. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #514582 Sun Jan 15 2017 6:07pm
W44NNE
Great replies, thanks
Post #514600 Sun Jan 15 2017 8:17pm
W44NNE
I checked the low range recently and all seemed well but haven't looked into the recalls; didn't realise there would be any so I'll look into it.
Post #514601 Sun Jan 15 2017 8:19pm
