![]() | Home > Maintenance & Modifications > Vibrating steering wheel when braking |
Worn suspension bush?? Visitor from fullfatrr.com
Orange RRS Member Since: 24 May 2016 Location: Lincolnshire Posts: 89 ![]() ![]() ![]() |
Have you tried checking for run out on the front brake discs, it's possible that a drive flange is distorted, if you can't do this try clamping off the individual brake lines but be careful driving it like this if you have to brake hard it will pull severely so be gentle on the brakes but it should indicate what side the problem is.
Did it have the brake judder straight away after you replaced the discs or was it ok for awhile ? 2008 G4 RRSport TDV8 current
Mark bridges Member Since: 23 Sep 2016 Location: Kent Posts: 5 ![]() |
The judder was there before disc change, and that made on difference at all thanks |
Hog Member Since: 03 Dec 2015 Location: Wassenaar Posts: 254 ![]() ![]() ![]() |
It could be a rusty/worn out cilinder in one of the front brake calipters |
Just wanted to update everyone, the problem was warped disc and pads on one side, caused by caliper sticking on, ended up replacing both Brembo calipers brake pads and discs,expensive but problem solved and no one wants to drive a Range Rover that wobbles like that, thanks for all your help, it was another part of this forum that pointed me in the right direction |
