Home > Maintenance & Modifications > FBH
Pakolainen
Finland 2013 Range Rover Sport 3.0 TDV6 Autobiography Rimini Red
FBH
Hi
I have the standard FBH in my 06 Sport, with 156000km on the clock.
I've yet to buy the timer / remote from Bodsy, and there is some uncertainty as to whether it ill actually work as a retrofit (at least my local indie says so....)
Currently the temperature is -17 degrees celsius. Went to start the car today and it took at least 5 minutes to actually start the engine. The FBH only kicks in when the engine is on? Which means for the most part when it is this cold it's only function is to try and warm up the fuel a bit quicker
Probably a silly query but just want to check. 2019 RRS P400e Autobiography
2014 RRS 3.0 TDV6 HSE Dynamic
2006 RRS 2.7 TDV6 HSe
Alfa Romeo Guillietta 2.0 JTDM 2011
Mazda 3 1.6 2010
Subaru Impreza 2.0 WRX 2005
Post #513540 Wed Jan 04 2017 3:41pm
Orange RRS
United Kingdom 2005 Range Rover Sport Supercharged Vesuvius Orange
The FBH is not used as a pre warming heater, it will only run when the engine is running allowing the engine coolant temperature to rise quicker to heat the interior and reduce emissions during a cold start and warm up.
The timer will allow you to preheat the vehicle before you start the engine. Life's too short to drive boring cars !
2005 Supercharged First Edition
2013 Evoque
Post #513542 Wed Jan 04 2017 3:57pm
I'm sure if I was in a place where it got to -17 I would have ordered a remote FBH start by now lol
Have faith, it will work. (as long as your FBH is currently working, check the FBH exhaust once the engine is running)
if cost is an issue, you could order one of these, and connect it to a manual switch inside.
http://www.ebay.co.uk/itm/Analog-to-W-bus-...SwA4dWI4YB
Post #513555 Wed Jan 04 2017 6:38pm
insiorc
Scotland 2013 Range Rover Sport SDV6 Autobiography Firenze Red
I understand the above, but won't the heater have it's own emissions? Probably much worse than the RRS engine, but not likely taken into account for the government & brochure's?
Dennis 13MY Range Rover Sport Autobiography SDV6 - mine
14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's
99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite
Post #513556 Wed Jan 04 2017 6:49pm
Ezituper
United Kingdom 2006 Range Rover Sport Supercharged HST Java Black
New to RRS how do you know if you have a FBH?
Don't be too harsh if it's stupid question of the day
Post #513557 Wed Jan 04 2017 6:51pm
phillh
United Kingdom 2005 Range Rover Sport TDV6 HSE Zermatt Silver
Ezituper,
Looking from the front of the car, it is under the bonnet, front right side and looks like this:-
https://www.bing.com/images/search?q=fuel+...ajaxhist=0
Post #513563 Wed Jan 04 2017 7:14pm
Eaters
Ezituper: see below cribbed from Tim:
Tim in Scotland wrote:
IIRC all Diesel RRS L320 (ie up to the introduction of the L494 models in 2013) have a built in auxilary diesel powered heater that should come on automatically when the ambient temperature is below 5c to help reduce cold start emissions. It is possible to retro fit a timer system and also remote control to pre-heat the engine on cold mornings to give you warm air from the heater more quickly. Often new to LR owners see smoke coming from below the front bumper or near side wheel arch and panic, but that is the exhaust from the heater. There should be a metal unit with pipes going into it under the bonnet on the passenger side just in front of the battery box which is the FBH.
. Not sure how it applies to petrol vehicles but look under the bonnet and see if it's there!
I second the thoughts from Andy K. I live in Sussex but still rate the recently installed remote for my fbh as a joy. Half an hour before I plan to go out I just press the LR button on my key fob. Then finish my morning coffee, go out and start the car (which starts that much easier) and push the fast defrost prog button on my heater. The coolant temperature has risen to the point where the screen immediately starts to clear helped by the heated front and rear screens. Don't get me wrong; it's not Hot. But the water temp gauge does move off its stop. Also side windows start defrosting. And I feel sure it must put less strain on the engine to be asked to start from warm rather than -17c!
And just for clarification, the fbh can be on its own as described by Tim above, or it can have a timer controlled start so that you can set it to come on at a set time, or it can be controlled remotely from your key fob. Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #513564 Wed Jan 04 2017 7:14pm
Dennis
Yeah that's about right Laughing
I guess if you have a tiny engine (running for a short Rolling Eyes time), making a massive engine more efficient, it makes sense
I don't think it's all about emissions though. Improves reliability and smoothness of the engine
Post #513572 Wed Jan 04 2017 8:28pm
Ezituper
phillh wrote:
Ezituper,
Oooo id better check tomorrow but does look like diesel only
Post #513582 Wed Jan 04 2017 10:06pm
removed
Post #513590 Wed Jan 04 2017 11:20pm
Bodsy
Site Sponsor
Re: FBH
Pakolainen wrote:
Hi
Well, like Finland, Russia has extremes of temperature and they love the remote units for the Webastos. You will find that with the FBH pre warming the engine, that it will start the engine much much easier than it currently does.
Your local indi sounds like he does not know what the Webasto is capable of....
The FBH will be independently started by the controller, it is not like a piston driven engine, it is a pure Fuel Burning Heater, so will fire up easier than an engine will. It definitely does not need the cars engine to be running although it will work normally when the engine starts.
I use mine all the time and whilst we don't get -17 here, it was warming the engine very nicely from -6 last week. About 30-45 mins later and the water temperature was 78 degrees C! Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #513596 Thu Jan 05 2017 12:40am
Pakolainen
Thanks Gents,
Bodsy, i will be in touch in due course, just need to get a Thailand holiday out of the way first. 2019 RRS P400e Autobiography
Mazda 3 1.6 2010
Post #513605 Thu Jan 05 2017 7:35am
