![]() | Home > General (L494) > What is inside the headlamp led "oval"? |
Andrew Member Since: 16 Jun 2005 Location: Cheltenham Posts: 249 ![]() ![]() ![]() |
Main beam spotlight.....
Clock Member Since: 04 Dec 2016 Location: Warks Posts: 34 ![]() ![]() |
Thanks for the info.
I think it is just styling, to give the distinctive DRL L.E.D 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Renaco Member Since: 28 Jul 2011 Location: Bavaria Posts: 325 ![]() ![]() |
No, those are housing the "corner" light spots, below 30 km/h when cornering those are working, if you have adaptive headlights! |
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 ![]() |
Nothing inside those ovals at all apart from some reflective "headlamp jewellry" on mine, which has adaptive bi Xenons.
No, the cornering lights are in the oval! |
They absolutely are not in that oval on my car, and yes I have double checked. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
udash Member Since: 16 Oct 2009 Location: manchester Posts: 196 ![]() ![]() |
Has two LEDs facing down, for corner lighting and also for Flashing, based on the size they looks like 1 or 3w LEDs.
Maybe this underlines it:
I think Renaco's answer is correct, I have just found the description on the configurator and it says they are static bending lamps to light the kerbside area in tight bends (with the ADAPTIVE XENON HEADLIGHTS options).
SDV6RRS Member Since: 08 May 2013 Location: Hampshire Posts: 52 ![]() ![]() |
100% they are the cornering lights. I think you get them regardless of adaptive headlights. My adaptive headlights swivel as I turn gentle corners, but those oval cornering lights come on on sharp'ish bends as well. It's very noticeable.
Never let it be said that I don't admit when I am wrong. So:
PetesRRS Member Since: 16 Jul 2015 Location: Melbourne Posts: 29 ![]() ![]() ![]() |
Same. But also find they come on when passing very close to an object. When I drive out of my driveway I pass very close to a brick wall and I find the right side lamp turns on and lights up the wall then turns off when passed. |
midsman Member Since: 24 Dec 2013 Location: West Midlands Posts: 63 ![]() ![]() |
I believe that only cars with adaptive xenon headlights have these little led cornering lights fitted. My car certainly has not got them fitted and I do not have adaptive headlights. So if you have adaptive headlights you have them, if not stop looking., they are not there.
