Home > Technical > Inlet Manifold TDV6
Sirrel Squirrel
Inlet Manifold TDV6
I've got an issue with my MY11 TDV6 RRS where I can hear air escaping when hitting over around 1800 RPM and the car goes into restricted performance mode. I took the car to an indy garage and they said it was the exhaust manifold, which is a body off job however looking into it further it is actually the inlet manifold, which is a fairly common issue.
Question is, can I do this fix myself or how much should I expect to pay for an indy to do it?
Post #513090 Thu Dec 29 2016 10:58am
Is it the 3.0?
Exhaust is common problem.
How do you know it's the inlet ? Where is it leaking from?
Post #513098 Thu Dec 29 2016 12:35pm
Sirrel Squirrel
The whooshing air sound is coming from the driver's side, roughly in line with the middle of the steering wheel and side grill near the top of the engine.
I found this thread earlier on another forum and it does appear to be the same issue - http://www.aulro.com/afvb/l319-discovery-3...blems.html
There's also a TSB out for it:
http://docdro.id/k7c5DY4
Post #513101 Thu Dec 29 2016 12:56pm
It's not a five minute job to change the inlet.
Remove the Y inlet at the front
disconnect injector pipes
remove injectors (and mark which pos they came from) Can be difficult to remove. Twisting helps. Plug holes
unbolt fuel rail
unbolt fuel rail bracket.
now you can almost get to the inlet bolts.
I think you also need to remove the cambelt cover at the front as there is a bolt or 2 behind that.
Fan needs to come off, which can be a right pain.
Slip Aux belt off.
Remove some tensioners
A job for a good LR indy
Post #513122 Thu Dec 29 2016 3:54pm
Disco_Mikey
It's about a day's work, in all reality. Manifold is £180 + VAT, from memory, and a few quid for injector washers
Post #513170 Thu Dec 29 2016 10:31pm
RRSporter
Hi just had this issue. P006A-00 code. As DM says it's a days work. Thus allow £900 for Indy or £1300 for LR. Plus the wait to sort. Like me it happened between xmas and new year. You could have a go with this method. £6, 2 hours work. 500 miles later, It's solid as a rock and airtight. Was only supposed to be a temp fix but Very Happy
 3.0 SDV6 HSE L494
Post #513320 Sun Jan 01 2017 11:04pm
Peanut
I do hope I am reading something wrong here!
The VIN range in this seems to cover my MY 2015 L494.
TECHNICAL BULLETIN
LTB00768v2 30 NOV 2015
Range Rover Sport (LW)
Model Year: 2014-2015
VIN: 600000-621222
Assembly Plant: Solihull
Engine: TDV6 3.0L Diesel Current: MY15 RRS2 3.0 SDV6 Autobiography Dynamic, Aruba Gold, HUD, Meridian 1700w
Gone: RRS TDV6 2007 Stornaway
Gone: P38 2.5 DHSE
Post #513327 Mon Jan 02 2017 11:03am
so what's going on in the first the last pic?
Are you creating a vacuum ?
Post #513331 Mon Jan 02 2017 12:54pm
lazysteve
Bulgaria 2011 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Hi, had this on mine. First left side, was replaced under warranty. 3 months later the right side went. Paid for the second one as warranty had just finished. All in was 750 pounds, done at dealer in Bulgaria.
Post #513336 Mon Jan 02 2017 1:15pm
RRSporter
Hi Andy
No just creating a diy version of a smoke test to find the leak. It's dead obvious though and doesn't need much pressure at all and a bit of wd40 or leak detector around affected area when pressurising with air.
The idea for this came from this link so I cobbled up what I could from my garage as everywhere was shut between xmas and new year, not because I was being a cheapskate. I needed a solution in 24 hours!
 3.0 SDV6 HSE L494
Post #513382 Mon Jan 02 2017 7:55pm
RRSporter
Btw the tech is not quite right in his video. As the engine is turbocharged the manifold pressure will be greater than the air outside it so air is blown out of the manifold not sucked in. It's this process which turns a hairline crack into a gaping hole when the engine is under higher load demand. For this reason it also needs a bit of pressure to show the leak up properly. It's right along the 90 degree radius of the manifold cover above the middle cylinder. You do have to cut away the bottom insulation in the middle cylinder area to see the crack. 3.0 SDV6 HSE L494
Post #513383 Mon Jan 02 2017 8:02pm
Arh I see Cool Cool
Post #513391 Mon Jan 02 2017 9:03pm
Sirrel Squirrel
Thanks for the replies, just waiting on a couple of indy's to get back to me.
What have you done in those pics RRSporter? Looks like glue?
Post #513427 Tue Jan 03 2017 12:52pm
RRSporter
Araldite rapid 2 part. The key component is the patch which had an almost identical radius to the manifold meaning a very small gap between the 2 plastic layers for the araldite to bond to. It was a section out of a screwdriver tray. All I could find but in fact was spot on. 👍. This won't come apart. The only way of failure is if the crack starts further along ie around the front or rear cylinder area. But these areas are supported by the ends of the inlet manifold which is the reason it fails in the centre usually as its least supported. 3.0 SDV6 HSE L494
Post #513428 Tue Jan 03 2017 1:15pm
ABSport
United Kingdom 2011 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
Re: Inlet Manifold TDV6
I had the same issue, mine was a fairly quick fix took it to Land Rover and there was a stuck actuator its above the drivers wheel arch. I thought Turbo etc body off etc Big Cry
Car was plugged in took out on road test actuator cleaned and all reset, I also had oil in the air filter, once all this was cleaned it's been fine since. Took it back last week and no oil in air box and no warning lights car runs perfect. Thumbs Up
I was told to stop driving around like miss daisy and open the car up use it for what it is, tbh I've never thrashed it in 3 years but now I open it up every day Whistle
Post #513468 Tue Jan 03 2017 8:26pm
