![]() | Home > Detailing & Car Cleaning > Snow foam photos |
zaphod Member Since: 16 Jan 2015 Location: Liverpool Posts: 290 ![]() ![]() ![]() |
I was going to buy a specialist lance and foam but thought I'd give it a go with what I already had available... I thought it did a pretty good job. There was loads of foam and it clung to the car for a good length of time - when I washed it all off the car was practically clean!
MFC V Member Since: 30 Mar 2016 Location: MK Posts: 14 ![]() ![]() ![]() |
Snoverfinch
CANROVER Member Since: 03 Oct 2015 Location: Ottawa Posts: 255 ![]() ![]() ![]() |
You must live in Birmingham Australia ![]() |
Stand Easy Member Since: 10 Aug 2016 Location: Manchester Posts: 126 ![]() ![]() ![]() |
Can I resurrect this topic, I've bought a new macallister pressure washer but I'm struggling to work out which connection I'd need for a snow lance. Has anyone got a macallister? It seems the old macallister fittings are slightly different to the new ones too. |
Danv8 Member Since: 20 Apr 2015 Location: Norfolk Posts: 378 ![]() ![]() ![]() |
If it's none of these, you you are going to find it difficult to find one [URL=]
If you can't find one the alternatives are, a replacement popular brand machine, or a hand pump sprayer. I also have one of these. [URL=]
How it performs [URL=]
[URL=]
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Because I have to lug my pressure washer out of the basement every-time I want to wash my car I rarely use it. Now I just use a normal soap dispensing nozzle off the hose after an initial pre-rinse and then a rinse and then the hand wash. I find Results are the same, it just takes a few minutes more but way faster than the time it takes to set the pressure washer up. This may change once I move into my new home with the double car garage |
Blueskye1 Member Since: 10 Sep 2016 Location: Carmarthen Posts: 80 ![]() ![]() ![]() |
Hi Canrover
Thanks pal, I'm sorted now, it turns out the fitment for a new macallister is the Lavor/halfords one whereas the older macallister uses the Bosch/ b&q one. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Glad I may of been assistance |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2015 ![]() ![]() |
Might try one of these on the garden hose with some snow foam.....
The local car wash guys based at our nearby large garden centre use diluted snow foam agent in a hand pumped Hozeloc garden sprayer, seems to get the same results as using it with a pressure washer. Certainly better than I can get with the Karcher reservoir and snow foam attachment that I have for my pressure washer. To the extend that I no longer use my Karcher for washing the RRS and go to the garden centre and listen to the radio while somebody else gets cold and wet for £6. Still use the pressure washer with a long lance attachment for cleaning the mud out of my Defenders underside nooks and crannies. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
