![]() | Home > Maintenance & Modifications > Rear Disc brakes - help ! |
tcfengineering Member Since: 21 Dec 2016 Location: Stockholm Posts: 4 ![]() ![]() |
Thats ideal, have found the bits I need, now I will order them. Thanks for your help |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5116 ![]() ![]() ![]() |
rear pads/calipers on the RRS aren't very big ! |
I am hoping that they will be OK, it is a peculiar application with a dual circuit brake system. I am going to run two calipers per wheel on the front and 1 per wheel on the back - its 6x6, so it will have 8 calipers in total, hope it should be OK. At worst, I can always swap the fronts out for twin pot front calipers, but then I will have to change the master cylinders also. |
Hello, its been a long time, but I now have some of the parts and it looks like it might work. I can mount the caliper and disc OK, but I dont have a caliper here yet and I am wondering if someone could check a measurement for me.
