Home > Technical > Please help with codes??!! Loss of power when driving :-(
Farmer Mel Tucker
United Kingdom 2007 Range Rover Sport TDV6 HSE Buckingham Blue
Hi all
I'm a lady farmer, with a 57 RR sport HSE, 109k
Love the car, but, recently I've had problems, with loss of power. I put my foot on it, nothing much happens Evil or Very Mad
My mechanic and I got together, and read some codes, now we are having a small wager on whether the problem is turbo or EGR valves.
Knowing my luck it will probably be both, however, please can you give me the benefit of all of your experience relating the to codes and the 'behaviour' of the car - if it helps, I get the message "engine system fault" but no lights
P132B-22 - Intermittant
P0490-00 - Exhaust gas (historic....it says)
P132B-22 - Turbo boost control A performance (?!)
Post #512151 Mon Dec 12 2016 9:03pm
Paddi
Welcome to the forum. The most common causes of power loss as described are splits in the turbo boost pipes and partially seized turbo actuator linkages.
The former is usually accompanied with smoke from the exhaust which you don't mention so maybe not the cause in your case.
The actuator linkages can be accessed from below or through the wheelarch if the liner is removed. Your mechanic needs to give it a good soaking with a lubricating spray and work it to and fro with a piece of welding wire or maybe baling wire given you are on a farm.
P4090 is I think an EGR related code so if the linkage is free but the problem persists the you might be losing that wager!
Also try searching this site for the term P132B to find other posts with alternative solutions since there may be a different problem.
Good luck and post up progress and any more information if you have any. 2008 MY Java Black TDV8 HSE
Post #512186 Tue Dec 13 2016 12:16pm
phillh
United Kingdom 2005 Range Rover Sport TDV6 HSE Zermatt Silver
This is what my manual says : P132B-22
Right-hand turbocharger boost control A performance - signal amplitude greater than maximum
Check the turbocharger and circuits. Refer to the electrical guides. Using a datalogger function, record the turbocharger actuator angle at idle and at 3,000 rpm. From idle, "blip" the throttle to maximum and allow to idle and record the turbocharger actuator angles. At idle, the angle should be approximately 95%, at 3,000 rpm, approximately 40%, and when "blipped" the voltage should change smoothly at approximately 25% per 100 ms. If the angles do not change, or do not change at the expected rate, suspect the turbocharger actuator is sticking. Install a new turbocharger. REFER to: Turbocharger RH (303-04F Fuel Charging and Controls - Turbocharger - TDV8 3.6L Diesel, Removal and Installation). Clear the DTCs and test for normal operation.
Post #512192 Tue Dec 13 2016 1:04pm
phillh
And for 0490-00
P049000 Exhaust Gas Recirculation Control Circuit High
EGR valve drive circuit short circuit to power
Refer to the relevant workshop manual section.
Not much help but it could point you in the right direction.
Post #512193 Tue Dec 13 2016 1:09pm
DrRob
Woody32 is your local guru on here. Somerset based. Might be worth a call? * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
I use www.glenrands.co.uk Great independent
Post #512194 Tue Dec 13 2016 1:19pm
Farmer Mel Tucker
Thank you! I'm so grateful for you all taking the time to reply. I am going to print all the answers and take it to him. He's a great mechanic and I think finds it a little amusing how much interest I take in my car, but not all ladies are afraid of getting their hands dirty!! I will definitely keep you all up to date on how we get on. Thanks again!!
Post #512231 Tue Dec 13 2016 8:09pm
jason-nike
Had a similar problem on mine.
Blanked the EGR and car was back to normal, full power
Post #512981 Mon Dec 26 2016 11:17pm
Farmer Mel Tucker
Please see post on faults and fixes for update
Not a good update
Then see new post on here - thanks Arrow
Post #513199 Fri Dec 30 2016 6:47pm
