![]() | Home > General > Brakes - Squealing and sticking - Any advice? |
How much faith do you have in the garage doing the work?
GSJ Member Since: 08 Dec 2016 Location: Cardiff Posts: 36 ![]() ![]() ![]() |
Hi Paddi,
Considering all the parts your garage has now changed there is no good reason for the brakes not to work perfectly.
Hi All,
....nearly forgot and maybe insightful info...
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2019 ![]() ![]() |
Get Bodsy to overhaul the EPB brakes when he's next in your area. He's the guru |
Hi DrRob,
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
The more I read through this thread the more I think you should be going back to the garage and asking for a load of money back. After they changed the calipers etc. any faults from that point on have been caused by them.
Hey SoCast,
My brakes creak and groan a little at low speed.
Tell me about it! I do feel a bit cheesed off, but lessons learnt now and I've exhausted that avenue, so drawing a line underneath it.
The cornering squeak will be caused by a wheel bearing on it's way out.
wheel bearing you say.... maybe silly Q, but is there a way i can confirm its the wheel bearing (s) before i take the plunge and have them replaced?
shakeapaw Member Since: 17 Dec 2011 Location: in a mud hut in wigan Posts: 948 ![]() ![]() ![]() |
jack the car up and check for free play by moving the wheel up and down and pushing/pulling it towards you, if there's movement, you have a problem 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater |
