Home > General > Strange noise on front of 2007 rrs help |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2009 |
Bush warming up as it's worked? Worth getting g on a ramp and use a pry bar Visitor from fullfatrr.com
Tue Dec 06 2016 8:43pm |
Tizzard Member Since: 30 Nov 2015 Location: Nottingham Posts: 64 |
To be fair I don't think I would find it with a bar as normal bumbs in the road it's fine it's just the high speed bumps when going over them. But why would the cat be fine to drive for the rest of the day? Even if I park it up for 3/4 hours then still fine when I get back in it |
Tue Dec 06 2016 8:57pm |
R1guy Member Since: 14 Nov 2016 Location: Driffield Posts: 9 |
I had the exact noise from the front on speed bumps, like a creaking garden gate. It was the center anti roll bushes. |
Tue Dec 06 2016 10:11pm |
Thanks for the advice When you say centre bushes do you men the ace bar bushes as I had a new ace bar and bushes fitted 10minths ago. So shouldn't think it should be them already as the hasn't even covered 2000miles since all fitted |
Tue Dec 06 2016 10:53pm |
yes the center bushes weather standard or active roll bar fitted. I would expect them to last longer than 2k, but not unheard of to fail very early.
Wed Dec 07 2016 8:52pm |
B9BS X Member Since: 19 Nov 2014 Location: Birmingham Posts: 420 |
Had the same problem too, turned out to be the front anti roll bar bushes, common fault, quick and easy repair to get rid of the creaky noise RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
Wed Dec 07 2016 10:04pm |
Well I got home from work last night and sprayed wd40 on the drivers side bottom wishbone bushes and also on the ace car bush. Took the car out and no squeak. So I will wait for it to come back then spray one bush at a time to determine what one it is. Cheers for the input everyone |
Thu Dec 08 2016 8:50am |
