![]() | Home > Faults & Fixes > Arrggghh Tow Bar! |
Remove everything under car including mounts possibly? That's all I have done on previous cars. John
If the detachable row hook has been left in the receiver for a long time then it is possibly corroded in place and will require "persuading" either with a big hammer or heat............. many owners never bother to remove them defeating the purpose of a removable hitch! For starters you could spray all the surfaces with plenty of WD40. I know someone who only got their tow hook off the car with a lot of heat and a Chainblock to put it out it was so well corroded in..... Before you remove the hook though, do you still have the plastic plate that filled wth cutout in the bumper? The car might look better with the towhook in place rather than with no bumper cover. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
hi,
adamm19830 Member Since: 21 Mar 2015 Location: Nottingham Posts: 45 ![]() ![]() ![]() |
I think my problem lies within the lock. My guess is that it has seized because I can only turn the key 1/4 of a turn clockwise. It feels like it could turn more which is when I snapped the key.
HemoRRS Member Since: 31 Mar 2016 Location: Wolverhampton Posts: 254 ![]() ![]() ![]() |
You want to try a penetrating oil, WD40 is actually for water displacement.
I've purchased some Graphite Powder today which is also supposed to be great at freeing up a seized lock. I haven't used it yet but I will if I get no luck with the wd40. |
Out of interest, for all of those that have a detachable tow bar, how much do you need to turn the key to allow the green lever to turn downwards? As mentioned I can only currently turn it a max of 1/4 of a turn clockwise... |
ShooterNeil Member Since: 14 Nov 2012 Location: Tamworth Posts: 422 ![]() ![]() ![]() |
The KEY only moves half a turn
So for the past week I have been squirting WD40 into the lock twice a day. The replacement key arrived today and the key still won't turn more than 1/4 turn and I can't shift the green lever down once pulled outwards.
Lyonhead Member Since: 21 May 2016 Location: Cardiff Posts: 351 ![]() ![]() |
It sounds like it could be the lock assembly now as you've tried 3 sets of keys and they all only turn 1/4 of a turn. It might be a goer to drench it in the new stuff you've bought but it might be prudent just to go for a new complete lock as you' ll know for definite that all is well with it. |
