Home > General > Cat Back Exhaust
dal74
England 2005 Range Rover Sport Supercharged HSE Java Black
Cat Back Exhaust
Afternoon chaps
As per the title really, I left work today and noticed on approaching my car that one of the exhausts was facing downwards MY2005 SC , on closer inspection and with a small wiggle (technical term) the back box completely snapped off leaving me with a rear end with one pipe Sad
I have located this cat back exhaust and thought it was reasonable price etc, my Q is : will this
http://www.johncraddockltd.co.uk/range-rov...ink-p.html
fit my car and also has anyone had any dealings with this company/ Exhaust itself
thanks in advance
Post #511044 Tue Nov 29 2016 3:17pm
Tim in Scotland
Craddocks are a respected supplier of all things Land Rover although they tend to provide more parts for older models like Defender, Discos 1,2,3 and earlier Freelanders. Maybe L320 RRS can now be branded as an older model! They are suppliers of parts often made by the OEM manufacturers but at lower prices than if you bought from an LR franchised dealership. You might even get one cheaper from a specialist exhaust supplier though. Are you going to replace both sides or only the one that has rotted through - might be the other is soon to follow it...... 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #511054 Tue Nov 29 2016 4:29pm
dal74
Definitely replacing both sides, the rear boxes look alot smaller than the ones on my car at the moment s i am assuming its not oem parts ? ie like for like?
Does that look like an ok system they have for sale? it is quite a bit cheaper than others i had seen/spec'd up
Post #511057 Tue Nov 29 2016 4:46pm
dal74
On a slightly different note, has anyone recently replaced their cat back exhaust on an L320 Sport? If so what with /make/ price please.
I just dont want to buy something ill regret later on
Post #511062 Tue Nov 29 2016 5:39pm
Orange RRS
United Kingdom 2005 Range Rover Sport Supercharged Vesuvius Orange
The other option would be a Magnaflow exhaust, a bit more sporty with no rear boxes. I have fitted several double S exhausts to other Land Rover models and wouldn't fit one to my own car.
Most people would prefer a little bit more burble but wouldn't want it droning at 60 mph whilst cruising.
I would recommend finding someone who will build a system to your own requirements as it wouldn't cost much more and you can have it how you want it. Life's too short to drive boring cars !
2005 Supercharged First Edition
2013 Evoque
Post #511066 Tue Nov 29 2016 6:00pm
dal74
Thanks orange RRS I have been doing some searching online and its looking like a bespoke system as off the shelf parts are getting scarce for early model sports it seems.
as a relative novice on these topics is a double s exhaust basically bottom end replacement for my car? I dont mind paying more if needed and would love to release a little bit of anger from the engine..
Post #511068 Tue Nov 29 2016 6:06pm
Spanner
I have a 2005 SC exhaust sat on my drive that I removed to fit a Magnaflow. I cut one of the studs off where it joins the front pipe but I've drilled it out already to accept a bolt. Other than that it's perfect. Feel free to pm me an offer Thumbs Up
Post #511069 Tue Nov 29 2016 6:09pm
dal74
Thanks for the offer spanner but ill pass as i am now looking at performance cat backs. may i ask how much you paid for yours? and is it a straight bolt on replacement?
Post #511070 Tue Nov 29 2016 6:12pm
Orange RRS
It's definitely a cheap and cheerful job., I want a bit more noise from my old girl but it's still in one piece at the moment.
I was thinking of a Magnaflow and if it was a bit too noisy fitting some rear silencers if I couldn't live with it.
Some manufacturers give on option of resonated and non resonated silencers
A friend of mine had a Vauxhall VXR8 with a switchable exhaust that was controlled by a remote control that went from loud to silent at a push of a button, I could live with one of those on my RRS. Life's too short to drive boring cars !
2013 Evoque
Post #511071 Tue Nov 29 2016 6:15pm
Paddi
The OP is quite near the legendary Hayward and Scott exhaust specialists in Basildon. Why not give them a call and see if they can fabricate a bespoke exhaust to your exact requirements? 2008 MY Java Black TDV8 HSE
Post #511077 Tue Nov 29 2016 6:28pm
Spanner
No worries. Yes it was a straight bolt on fit, massive weight saving too. I paid a couple of hundred quid for mine off a mate on here
Post #511078 Tue Nov 29 2016 6:31pm
Orange RRS
Is your Magnaflow exhaust without rear boxes and does it drone t cruising speeds on light throttle. Life's too short to drive boring cars !
2013 Evoque
Post #511086 Tue Nov 29 2016 7:07pm
DrRob
Fruity Thumbs Up
http://www.griffinperformance.co.uk * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
I use www.glenrands.co.uk Great independent
Post #511088 Tue Nov 29 2016 7:13pm
dal74
Bit the bullit and went for this bad boy Smile
http://www.ebay.co.uk/itm/Range-Rover-Spor...1263739306
Post #511089 Tue Nov 29 2016 7:15pm
Orange RRS
Just out of interest how noises was it with only one back box, Life's too short to drive boring cars !
2013 Evoque
Post #511094 Tue Nov 29 2016 7:52pm
