Home > General > wading :)
david555
wading :)
Hello all. Although a member not quiet an owner. Waiting for my car to sell and buying a rrs sdv6.
Looking to do some light off roading and quiet fancy the possibility of wading, seems very fun. But came across this picture which I thought could be useful to some people, but mainly for the fact that a rrs has a higher wading depth then a defender...... Excuse me? Am I correct in thinking that the main reason for this is the defenders door seals lets water in and rrs doesn't?[/quote]
Post #510605 Wed Nov 23 2016 7:52pm
david555
Post #510606 Wed Nov 23 2016 7:53pm
Tim in Scotland
That poster is a little bit out of date as wading depends which MY of RRS and FFRR. I have a 1996 TDi 300 Defender and an L494 RRS2 and the RRS2's intakes are on the wing top just under the clamshell of the bonnet so with off-road height selected I have 1m wading whereas my 1996 Def has a lot more with extended axle breather, bell housing plugs in and it's Snorkel (it isn't the LR Raised intake which isn't water tight!) BUT normally I wouldn't take the 90 deeper than intake depth which for my 90 is 50cm. L320 RRS (I've have also had 2 of them and offloaded both quite heavily) has the same 50cm as my Defender as the intake is on the wing side - also the RRS OEM Raised intake cannot be used for deep wading as it also is not watertight out of the box, you have to put your own seals into it (and hope they are watertight!). The other problem with pre Puma Defenders is the under windscreen vent system and the ventilation holes around the battery box under the front passenger seat which all let in loads of water......... BTW both my Evoques also had as much wading depth as my 90. The 2 x FFRR's I had both had 50cm wading but L405 has 1.0m like RRS. I believe DiscoSport has 75cm but need to check that. Disco5 has 1m as well.
It is almost as it left the factory and has standard suspension and Zu lightweight 16" alloy wheels and BFG MTRs 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #510610 Wed Nov 23 2016 8:36pm
david555
I'm getting a 2012 sdv6. Old shape but face lifted I believe.
What's the wading depth do you know, completely standard? And will I get wet feet at this depth like my friends 90 ?
Post #510616 Wed Nov 23 2016 9:54pm
DrRob
Rule of thumb = wheel centre max Thumbs Up
Water and modern LR electrics don't mix * Current: 2024 D350 Defender 90 on coils!
* Current: 1974 Lightweight 2.25L petrol. Old skool
* GONE: 2012 RR Sport HSE SDV6 Orkney Grey. Now being piloted by RRSTDV8
I use www.glenrands.co.uk Great independent specialist!
Post #510617 Wed Nov 23 2016 10:01pm
Buckster
Shocked so when it comes over the bonnet momentarily I should worry Rob Question Whistle Rolling with laughter 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #510620 Wed Nov 23 2016 10:16pm
DrRob
Nah...you have a snorkel Thumbs Up Rolling with laughter Bow down * Current: 2024 D350 Defender 90 on coils!
Post #510622 Wed Nov 23 2016 10:31pm
riverblanche
its more important to keep water out of the Engine, Gearbox, Axles and Electrics than keeping the carpets dry Thumbs Up
Wheel centres is a good guide Whistle we were running 235.85.16's so just over 600mm while crossing and bonnet dipped under when we went in
On a more serious note it also proved its self during the floods of 2007/2008 when we needed to ford a road helping out in our village and a small bow wave was lipping the top of the bonnet, concerned if any man hole covers had been lifted Shocked the carpets did need to come out after to be dried
Post #510623 Wed Nov 23 2016 10:40pm
ilard
Whilst I had no prior plans to leave my wife I am now seriously considering eloping with your Defender.
600 mm standard height, 700 mm off road height. I don't think you get wet feet if the door seals are good and in any case you'd have a bow wave that would reduce water around the doors, I think. (Not waded more than 100 mm myself!) L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Post #510637 Thu Nov 24 2016 10:09am
david555
So what are peoples recommended things to do and protect so I can go full wheel deep, without having any major issues apart from drying out my feet.
Post #510638 Thu Nov 24 2016 10:09am
Tim in Scotland
IIRC LR have moved things on a bit since they designed the Defender watertightness which hasn't changed much since 1948! I have not had any issues with deeper wading in either of my L320 RRS's or the L494 I run at the moment BUT I certainly wouldn't take them to full wheel height depths of water unless it was an emergency. Is it your intent to run the car as a purely off-road toy with no normal use, as you may well be the first owner here to have an RRS for wrecking during off-road play? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #510641 Thu Nov 24 2016 10:17am
Buckster
Depends how far you want to go with it!
You can fully seal raised air intake, enclose the ECU behind the battery in a water tight container. But ultimately if your in that deep you will go into super extended height on the suspension and probably be floating by that point!! Rolling with laughter 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #510642 Thu Nov 24 2016 10:38am
david555
If it was a pure off road toy id buy a defender to be honest!
I want a decent car that's nice to take the family out but something I can have fun in.
I'm only really looking at mild off roading and some good wading (looks so much fun)
Maybe I'm not being realistic and full wheel height might be deeper then I'm thinking!
Post #510644 Thu Nov 24 2016 10:47am
david555
Judging by the photo I posted at the top, which is meant to be for standard vehicles. The range rover has the wheels covered?
Post #510647 Thu Nov 24 2016 11:08am
Buckster
This is a sport from a member on here a few years back! Whistle 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #510651 Thu Nov 24 2016 11:51am
