![]() | Home > Technical > Gearbox Clunk |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1559 ![]() ![]() ![]() |
I've had my RRS since March 2016 and noticed that there is a clunk when reapplying power after say you slowed down at a roundabout and then applied a fair amount of power (say 25%) to get moving fairly quickly. Its as if it hadn't pre-selected the correct gear and clunked in when the power is applied. If you give it a couple of seconds, or apply very gentle power then clunk doesn't occur.
Hog Member Since: 03 Dec 2015 Location: Wassenaar Posts: 254 ![]() ![]() ![]() |
It might be a mechanical issue as well. However if you have the gearbox drained again, have it flushed and also have the filter(which is integrated with the oilpan) changed. succes1 |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2019 ![]() ![]() |
Don't drain and fill. Have it flushed.
Cheers Guys - just the sort of feedback I was hoping for - and thanks for the PM Dr Rob Robin
Thanks for that Russben. I understand what your driving at and to be frank, now you mention it I'm not sure. As I've just been hitting the scotch 🍹I can't take it out to check now ( hey, the sun's well over the yardarm). But when out tomorrow I'll make a point to check. Good thinking though!👌 Robin
Russben Member Since: 27 Mar 2013 Location: Lancashire Posts: 278 ![]() ![]() |
No problem & happy to help.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4521 ![]() ![]() ![]() |
I battled with this for long enough on my own car. Eventually traced it to a worn front prop |
Brayanmarro Member Since: 13 Jul 2025 Location: Massachusetts Posts: 1 ![]() ![]() |
Hi Eaters, what was causing your symptoms? I have a 2014 RRS that has the same issue. Look forward to your response. Cheers! |
I have lived with the clunk ever since my post in 2016. I tend to try to anticipate it now so that I am more gentle with the acceleration. I don't have paddle shifts but do tend to slip it into sport mode if I am approaching a busy junction to help with pulling out in a hurry so the suggestion of the gearbox selecting a lower gear does sound plausible. However, it still feels like a worn joint somewhere in the drive train to me (See Disco Mikey's comment about the front propshaft). I'm amazed that it has survived this long without a sudden loss of drive! I guess I'll just soldier on with it with fingers (and everything else) crossed. Robin
