| RRSPORT.CO.UK | ||
|  | Home > Technical > RRS Knocking front suspension/loose rearend |
| Tim in Scotland Member Since: 30 May 2005 Location: Driving along in my automobile Posts: 17476    | Yours is an HSE, do you know if it has what was an option on 2.7 HSE's - Dynamic Response - which is electro-hydraulic rear anti-roll bars. It could be that the fluid needs either topping up or changing. You can tell if the car has DR fitted by the additional filler cap at the front of the engine bay. Another thing to check are that the ride height sensors are all working - go into the 4x4 screen of the central screen and there are icons of white bars above each wheel icon, if any are red then there is a connectivity  or sensor issue. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
|  Wed Nov 16 2016 7:48pm |
| arnulf Member Since: 16 Nov 2016 Location: Oslo Posts: 5      | Hello Tim!
|  Wed Nov 16 2016 7:52pm |
| Tim in Scotland Member Since: 30 May 2005 Location: Driving along in my automobile Posts: 17476    | The refill is dead easy! It has it's own filler at the front of the engine bay! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
|  Wed Nov 16 2016 7:54pm |
| arnulf Member Since: 16 Nov 2016 Location: Oslo Posts: 5      | doh... this might get emberrassing   | ||
|  Wed Nov 16 2016 8:03pm |
| arnulf Member Since: 16 Nov 2016 Location: Oslo Posts: 5      | Oil level slightly above minimum. Topped it of with gulf DIIIH. Overfilled actually.
|  Thu Nov 17 2016 5:43pm |
| SHARPIEV8 Member Since: 05 Jul 2016 Location: NORTHAMPTONSHIRE Posts: 2    | I have a '57 RRS that sounds like the same model as yours.
|  Mon Dec 12 2016 2:52pm |
| arnulf Member Since: 16 Nov 2016 Location: Oslo Posts: 5      | Turns out the airdryer was clogged up by deterierated dryer beads. Completly  plugged. I suspect there is debree throughout the system causing intermittent faults. Fixing the dryer fixed the fault.
|  Mon Dec 19 2016 9:48am |
| Posting Rules
 hillstarting in sandy hills where the GD240 wont climb going in with speed. Terrain respons and the autobox rocks!
