Home > Technical > Flashing issue on 4x4 info screen
Paul_selby
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Fuji White
Hi all . After some info if possible , last night noticed after parked my 2006 s/c up in access mode the rear end was sat uneven ( maybe 4-6 inch) with the nsr lower . I checked on the 4x4 info screen and the little minus sign above that position flashes red , only in access mode . Whilst parked in normal ride height there is no issue. I have an mot tomorrow so ideal chance to get under and have a nosey . What I'd like to know is if it is the height sensor , when I replace it should I have the vehicle in a specific height mode , and also I have been told that disconnecting the battery before would remove the need to have the calibration done ? Any advise greatly received Very Happy
Post #510075 Mon Nov 14 2016 6:45pm
Bodsy
Site Sponsor
If the height sensor is changed, it will still need the calibration doing, regardless of wherpther the battery is disconnected or not. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #510077 Mon Nov 14 2016 7:25pm
I wouldn't change anything.
Either live with it.
Or Calibrate it to see if it sorts it.
Post #510080 Mon Nov 14 2016 7:30pm
