![]() | Home > General (L494) > Leaking rear differential seal |
kelvin12382003 Member Since: 12 Mar 2016 Location: Hong Kong Posts: 2 ![]() |
I have the same issue. what do i need to do to fix it? |
Tony, which MY is your car as I have oil on my drive after the car has been sat for 6 weeks and it is not from my Defender as that has been in secure storage and marking its territory somewhere else! My RRS2 is a March 2015 build and delivery 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
mine is a 2013 autobio. i also found some oil leak on my drive!! |
TonyM Member Since: 13 Apr 2014 Location: Southampton Posts: 7 ![]() ![]() ![]() |
That RRS2 was on a 63 plate. Dealer checked levels and advised to monitor whilst the tool was obtianed. Since changed to 16 plate model amd no issues.
Peanut Member Since: 31 Jul 2012 Location: Leicestershire Posts: 110 ![]() ![]() |
Same problem 2015 MY Autobiography.
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 ![]() |
Had a new diff fitted to mine a short while ago for the exact same issue. MY16. 13k miles
PetesRRS Member Since: 16 Jul 2015 Location: Melbourne Posts: 29 ![]() ![]() ![]() |
You must need a step ladder to get in and out of that, lol. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Russben Member Since: 27 Mar 2013 Location: Lancashire Posts: 278 ![]() ![]() |
That's one heck of a caravan |
Yeah van is certainly high but great off road. Now just had a call from service guy. Found oil leak in diff but also found a bearing rotates in diff housing therefore new diff required. I have a rear locking diff and none available in Australia. Has to be ordered from U.K. Will take a minimum of 2 weeks to arrive. Guess I will just have to enjoy the new Evoque they provided.
IRBails Member Since: 22 Nov 2013 Location: Wollongong Posts: 873 ![]() ![]() |
I have 26,000 up now and hope they fixed the issue in the 2016 models. seems a very common problem. Like the Van pics also the use of the RRS as a true 4WD vehicle. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
mlines Member Since: 10 Dec 2006 Location: UK Posts: 480 ![]() ![]() |
MY16 (Sept 2015) Autobiography Dynamic. In at dealers to fix a brake pedal noise which was diagnosed as Fuel Tank Slosh. When removing the tank they discovered oil leaking from the differential so now having the seals replaced and the differential checked. 2016 RRS 4.4 TDV8 Autobiography Dynamic in Montalcino Red and Stealth Kit |
