![]() | Home > General > sdv6 buying advice |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2796 ![]() ![]() |
Welcome to the forum |
david555 Member Since: 08 Nov 2016 Location: east Yorkshire Posts: 28 ![]() |
http://m.ebay.co.uk/itm/2011-61-Land-Rover...Ciid%253A2
It looks factory standard - no unwanted mods or unsightly accessories. I appreciate your comments regarding mechanical know how & support but the parts are |
Thank you for your help |
It's all about personal taste - the AB has the exterior pack which can also sometimes be found on the HSE - rear privacy glass is also a nice touch |
Yeah I know what you mean.
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2019 ![]() ![]() |
Have Land Rover got any in your price range under their Approved Used? They come with 2 years warranty..... |
Hello. Currently not. Last time I looked they had nothing pre 14 plate |
Sorry, but...
Take this along with you - it's for the pre facelift model but the later version is predominantly the same |
David, to check the "off road mode" the only thing you need to do is to start the engine, put the main gear selector to N and then move the Hi/Lo transfer switch into Low. It will then activate the transfer case by an electro hydraulic mechanism that should operate smoothly and quietly. If you wind down the driver's wind before pressing the Hi.Lo rocker switch then you might hear a quiet noise as the system changes over, it will make a quiet noise but nothing clunky or noisy. Apart from that you cannot check the operation of the Terrain Response system - it is fully electronic and as you switch betweem settings it will remap suspension/engine/ gearbox ECU's and will request activation of the Hill Dscent Control on some of them. After checking the transfer case operates OK (or not), re-select Hi and the change back should again be smooth and quiet. If the car is one with the optional e-diff fitted (or is on where it was standard fit) there is no way to test that. BTW NEVER drive the car on a hard surface road in low ratio, you cause transmission wind up that can damage the transmission system. Only other bit of the off-road gear is the suspension which should go up to off-road height quietly, smoothly and quickly. Even if you never intend to take the vehicle off-road you should still test the Hi/Lo change over operates - it isn't hugely expensive to repai but if the car has been properly looked after it should have been operated at a minimum monthly - I suspect that the vast majority of owners don't even know what the transfer box is or does and never operate the system............ it will then seizing up through lack of use. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Thanks peachy very good document!!
One last question before I take the plunge and spend alot of hard earned cash (took me ages to convince the misses to give me the money!) haha
The later models seem to be more reliable than the 2005 -2009 (pre-facelift) L320's , but you really must be prepared for a disaster with any used LR product............... having said that I also own a 1996 Defender that has been seriously abused off-road - it has never broken down, in 20 years it has had a replacement chassis (a known issue with 1996 TDi300 Defenders) due to severe corrosion (cost me £2000 including a new galvanized chassis to repair), a new transfer gearbox (because I ran it for 100 miles with no oil in it after landing heavily on an underwater rock while off-roading in deep water), a replacement rear door last year and 1 new battery. It was delivered with the optional cat on the exhaust but when that went I had the EGR blanked and the electronics removed about 10 years ago. That's been it in 20 years! It does about 2000 miles a year but 90% of them are heavy off-roading - i.e. Using the car for what it was designed to do! It also has no fancy electronics to go wrong. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
