Home > Maintenance & Modifications > Exit lights on bottom of doors
Pakolainen
Finland 2013 Range Rover Sport 3.0 TDV6 Autobiography Rimini Red
Do the door lights only support same type of bulbs or can LED versions be added.
before i go out and buy LED's 2019 RRS P400e Autobiography
2014 RRS 3.0 TDV6 HSE Dynamic
2006 RRS 2.7 TDV6 HSe
Alfa Romeo Guillietta 2.0 JTDM 2011
Mazda 3 1.6 2010
Subaru Impreza 2.0 WRX 2005
Post #509232 Thu Nov 03 2016 2:45pm
Socast
I replaced mine with LEDs all round, it's worth cutting into the housing a little then you can fit a panel with either 8 or 12 LEDs rather than a single.
I used these in all four doors and in the boot as well:
http://www.advancedfactors.co.uk/glo133-12...4777-p.asp
LEDs have a positive and negative so will only work when fitted to the correct polarity (unlike a standard bulb), so if the don't work unplug and flip them round the other way.
Post #509234 Thu Nov 03 2016 2:59pm
Pakolainen
perfect.
thanks
Steve 2019 RRS P400e Autobiography
Mazda 3 1.6 2010
Post #509235 Thu Nov 03 2016 3:07pm
riverblanche
AF led's are good, but I replaced mine with canbus ones off ebay 10 for less than £5 fine for the ones in the doors, footwells, glovebox, rear reading lingts and 3 centre lights, about a dozen inside alone Rolling Eyes
use the AF ones if you are going to do side lights, number plate lights.
Third car I have replaced them on and only had 1 that was temperamental 1 of the 5 led kept going off randomly
Post #509246 Thu Nov 03 2016 7:04pm
Eaters
Do the canbus ones used in the interior lights fade correctly? Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #509292 Fri Nov 04 2016 9:18am
riverblanche
Hi
yes they all work fine Thumbs Up
this is on the previous car, front led rear original
Post #509332 Fri Nov 04 2016 5:36pm
Eaters
Cheers Riverblanche. Robin
Gone:
MGZTT 190 2.5
Post #509333 Fri Nov 04 2016 5:43pm
Blueskye1
Wales 2008 Range Rover Sport TDV6 HSE Java Black
Replaced mine as well Shocked
The pic on Riverblanche's post also shows that the light only is bright in one half of the bulb holder mine is the same any reason Question
My 7 series beemer had 18 internal lights
Andrew My first RRS HSE Purchased June 2016
Java Black 2.7
Date of first registration 22 February 2008
Cousin of the King of Stamford Bridge R.I.P. Ossie
Post #509335 Fri Nov 04 2016 6:51pm
Eaters
Not having fitted them yet but I would suspect it is just that the bulb is located at one end rather than centrally. I have seen replacement kits which have LED right across the length of the holder. More expensive but might be worth a try in the future. I'm also wondering about the coloured option for the foot wells. Anyone tried them? Robin
Gone:
MGZTT 190 2.5
Post #509338 Fri Nov 04 2016 7:01pm
Blueskye1
Thanks
I would suggest the version suggested with the light 100% across the whole light Exclamation
Found a few sets on e-bay
https://www.ebay.co.uk/itm/172234011323
https://www.ebay.co.uk/itm/252051051665
Powerful U.K. Offering..
http://www.powerfuluk.com/vehicles/range-r...white.html
Not sure how good these are .
Any of our sponsors offer these with a discount Question
Java Black 2.7
Post #509339 Fri Nov 04 2016 7:12pm
Blueskye1
Answer to the problem I posted & solution Confused
Also shows some blue lights in the footwells hope this helps.
Java Black 2.7
Post #509344 Fri Nov 04 2016 8:24pm
Eaters
I've just purchased and fitted these: http://www.ebay.co.uk/itm/272128114698?_tr...EBIDX%3AIT
and they work fine. And, as riverblanche says the gradual dimming still works as well - (how could I ever doubt it?). For £4.99 and free delivery, what could go wrong?
Two things I noted - if they don't initially work, turn the bulb around as they are polarity sensitive, and when doing the nearside footwell bulb (which is tucked as far forward as they could make it) don't pull too hard or you'll separate the bulb holder from its wire plug and that means removing part of the trim below the glove compartment to reconnect it again!
On my 2008 TDV8 I count 11 interior bulbs that I could replace and so with a pack of 10 I left the glove compartment bulb as original and replaced all the others. It would be nice to have another light in the boot area - perhaps that's a mod for another day. Robin
Gone:
MGZTT 190 2.5
Post #509756 Thu Nov 10 2016 3:38pm
Blueskye1
Andrew
Just replaced number plate lights with LED's
I had replaced front door lights with LED's but as posted before not happy with only half being illuminated reason in pic so will replace with full LED's as shown in luggage area Cool
Rear doors to be done soon old yellow still fitted very poor Sad
Andrew Very Happy My first RRS HSE Purchased June 2016
Java Black 2.7
Post #509759 Thu Nov 10 2016 4:32pm
Eaters
I can understand where you're coming from Blueskye1 and it may well be that I'll move on to the full LEDs but for a fiver I thought I'd give them a try. Looking forward to dark to see the improvement.
Does anyone know if the upper glove box has any illumination? Robin
Gone:
MGZTT 190 2.5
Post #509768 Thu Nov 10 2016 5:31pm
Blueskye1
Eaters.. Idea
Anything has to be better then the smoke stained looking yellow ones Thumbs Up
Java Black 2.7
Post #509770 Thu Nov 10 2016 5:45pm
