![]() | Home > In Car Electronics > HDC Fault, Transmission Fault, Special Programs Not Availab |
Are you still having the faults messages about HDC and the other things in your original post or are these now fixed? Sorry to have to ask but it isn't clear from your most recent posts.
nas16309 Member Since: 28 Sep 2016 Location: london Posts: 22 ![]() ![]() ![]() |
Hi Paddi, hope all good. Sorry been late in replying as other issues came up not with car.. everything goes wrong at times!
There are many contributors to this forum whose knowledge of these cars is far superior to mine. However I do know that the Park Brake Fault message tends to be displayed just after starting if the battery is low. The starter motor draws a high current that leads to a voltage drop and if the battery is weak the drop is sufficient to trigger spurious messages.
CRACKA Member Since: 16 Sep 2014 Location: Hallam Victoria 3803 Posts: 170 ![]() ![]() ![]() |
Hi all from down under.
Still having issues - can't get RRS looked at until Thursday.
Hi Paddi
It's a bit weird that the battery is charged but the 'Park Brake Fault' warning still comes up in the message centre even if it is only for a couple of seconds.
Hi Paddi
Well I have been to a very good Indi as you call them regarding my Fault codes and system malfunction messages.
Hi Paddi and others,
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5062 ![]() ![]() ![]() |
didn't you put the ctek on before you went away for 3 weeks ? |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9074 ![]() ![]() ![]() |
If the battery is knackered, the Ctek won't make it well again. Once the battery has lost a cell then nothing other than a replacement will help. The Ctek will put charge in and tell you it's fully charged but, well, it isn't. BTDTGTTS. |
