![]() | Home > General > BUYING MY FIRST RANGE ROVER SPORT HELP |
Timf Member Since: 27 Feb 2010 Location: East Anglia Posts: 312 ![]() ![]() ![]() |
Led, I have had two and generally no trouble in 100,000 miles but you must read the various threads here. Like any vehicles there are good and bad but I'm convinced the bad second hand ones are the result of being abused. Treat them well and they are great. Regular servicing, not being thrashed from cold etc.. all pays off. The regular woes are front suspension/steering knock (bushes which are easily replaced) alternators (which are quite a big job on a TDV8 as a lot of engine needs to come out for replacement - I have had one go west) and general electric gremlins many of which are due to a worn out battery. Kept in good condition, a TDV8 is very rewarding. Your find has a very low mileage for an 07. Has it got service history? If you buy it, get a Warranty - peace of mind as much as anything. You might have to shop around as several don't like 10 year old vehicles (as yours will be soon). I have had Warranty Direct who were okay on claims for alternator & bearings. Good luck |
Sorry didn't read your post properly - service history & receipts sound good |
Led Member Since: 22 Oct 2016 Location: Stockport Posts: 3 ![]() ![]() |
Thanks for the reply,
Led, turbo's are another TDV8 issue but I've not had trouble, and although there are several on this forum who have, I guess we hear more from those who have had trouble than those who haven't. Warranty Direct cover them, and others will too but read the smallprint |
The only way to tell if it is a genuine Overfinch and not just eBay purchased bits stuck on it is to contact Overfinch BUT they have had so many changes of ownership/ bankruptcies over the years that they often don't have the paper records or will just decline to tell you............... If it has had any engine modifications then it won't be covered by any Land Rover warranty at all, bodywork mods generally are not a problem. Is the seller a franchised Land Rover Dealer, a non franchised LR specialist or just a 2nd hand car dealers? If the first two then it shouldn't be any problems, if the last one then insist that before you buy it that they get it into a franchised dealership service bay for a good going over, any outstanding recall/TSB work to be done and a service. As it has had an Overfinch body kit fitted it is extremely unlikely that it will have been off road......... but still check underneath for damage, also check that the transfer box works smoothly and quietly (even if you never intend to go further off road than Tesco's Car Park the kit should all work). Check that the suspension goes up and down smoothly and quietly and that the car sits level. Overfinch are "bespoke" car rebuilders so there is no way to know what level the previous owner went to with mods, some are just a body kit , some are just a replacement interior and some are hugely expensive engine, body and interior rebuilds, often to a brand new car.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9099 ![]() ![]() ![]() |
This might be a worry as the rev counter is driven by the engine ECU using info from the crank position sensor. Replacing that sensor is an engine out job (which is itself a body off job). The sensor is between the flywheel and the engine block. Not sure if the failure of the sensor would lead to the car throwing a "I'm not going to work" fit. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Led, I'm glad you've seen an alternative. Some love them, but vehicles with additional bodywork can appear a bit 'look at me' but rather miss it altogether! They can date fast and if they get scuffed they look far worse than a standard vehicle. As Tim in Scotland says, beware anything non-standard for warranty and insurance issues |
M12UPY Member Since: 03 Dec 2015 Location: Manchester Posts: 81 ![]() ![]() ![]() |
Get it bought and welcome to the club |
