Home > Technical > Can someone please help me with my range roversport
Loverrs
Ok this is what happend I toke the range rover to my local remapped at local Manchester the guy done the job driving is perfect more file economic.
After 48 Hrs I can see smoke from the exhaust and engine system fault the guy put the original files back but still the same and getting smoke and engine system fault when in around motorway 50 to 70 mph I can see more smoke . And the guy saying it has noting to do with the remap the fault was there before I do the remap . I have serviced the car back in June and I never seen this fault with my car no smoke or fault error .
Can someone tell me pls if there anything I can do to fix this problem .
Today the guy delete egr and now I'm getting error . And now I'm getting error at the close where the MPH . Please see the photo .
Post #508218 Thu Oct 20 2016 10:35pm
Bodsy
Site Sponsor
Fill in your profile will help us to help you.
Tdv6 or 8?
What year? Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #508222 Thu Oct 20 2016 10:55pm
Loverrs
Hi
I have edit already
I have range rover sport hse 2009 2.7 v6
Post #508224 Thu Oct 20 2016 11:01pm
Loverrs
This is what I'm getting I think this is something to do with engine . Please see the photo
Post #508226 Thu Oct 20 2016 11:06pm
Bodsy
Site Sponsor
Can't see a picture, but I'm guessing it's the engine management light. It needs to be properly software updated to stop that coming on when you blank the egr on your year car.
Is the remapper used to doing Rrs or does he do Generic loads of different cars?
Personally I'd say get the cheap map removed and I'd be happy to put a reputable proven RRS focused remap for you. I'd check your fault codes first to see what the issue is.
When you say you have smoke, is it big billowing clouds of black smoke? Bodsys Brake Bible
See it HERE
Post #508227 Thu Oct 20 2016 11:09pm
Bodsy
Site Sponsor
Yes, I see the picture now. It is the engine management light, the egrs need to be software updated to stop the eml coming on. Bodsys Brake Bible
See it HERE
Post #508228 Thu Oct 20 2016 11:11pm
Loverrs
Thanks bodsy the guy said egr blank .
The guy already put the original back to the car .
But delete or disable the egr.
I'm in Manchester I don't mind coming all the way if you know how to fix the issue .
Post #508234 Thu Oct 20 2016 11:49pm
Bodsy
Site Sponsor
It's a case of availability. I'm in Oxford and Coventry Wolverhampton tomorrow, then in Watford all day Saturday. Monday I'm in Andover area.
Possibility for Tuesday. Drop me a message with your address and if you can, a bit more info on the current problems you've experienced. Thumbs Up Bodsys Brake Bible
See it HERE
Post #508235 Fri Oct 21 2016 12:06am
Loverrs
The smoke is OK now not alot when I put the car in Parking and press the padel all the way down I can see the smoke ..
If I blank the egr well it fix the issue.
Post #508237 Fri Oct 21 2016 12:29am
mnk
Hi Ian, just read your post above about being in Watford, I live in Watford and was hoping to meet you to discuss a few things? PM me please.
Post #508238 Fri Oct 21 2016 12:36am
