![]() | Home > Maintenance & Modifications > TPMS |
TPS Member Since: 12 Oct 2015 Location: Buckinghamshire Posts: 127 ![]() ![]() ![]() |
Hi all. I need to replace tyres on my 20" alloys (early my2012) and was thinking to add TPMS at the same time. Is there an easy way to retro fit the RRS TPMS? What's the easiest way to check if it's already fitted and if not, Can the system be purchased as a kit? -----------------------------------------------
Danv8 Member Since: 20 Apr 2015 Location: Norfolk Posts: 378 ![]() ![]() ![]() |
There are 100's of aftermarket kits, all can be retro fitted, just depends how much your willing to spend and what sort of kit you want, I.e standalone monitor, normally requires hard wiring in, aux socket adapters with tiny LCD displays just needs plugging in to lighter socket, or App based systems which connect to your smart phone via Bluetooth.
Thanks Dan
You should be able to fit the Land Rover TPMS module since the wiring is probably already there and then enable it by reconfiguring the CCF.
Thanks Paddi.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5120 ![]() ![]() ![]() |
Don't bother trying to retro-fit the factory system it's not worth the effort or cost as it's pretty usless. I have it as a factory option on a MY13 car and all it does is flash a Amber Warning if the tyre drops to around 20-25 psi. thats it, no pressure reading or ànything else.
Thanks all for the help and advice. |
IRBails Member Since: 22 Nov 2013 Location: Wollongong Posts: 873 ![]() ![]() |
I did some searching on these systems a while back:-
