| RRSPORT.CO.UK | ||
|  | Home > In Car Electronics > What dash cam |
| Buckster Member Since: 05 Mar 2015 Location: Hampshire Posts: 1656      | I believe the next base is good for within your 100 budget you have set.
|  Sat Oct 08 2016 4:49pm |
| Danv8 Member Since: 20 Apr 2015 Location: Norfolk Posts: 378      | I have a nextbase 402g installed, it's good but they all suffer from internal battery fail normally around 10 months, so then it's back to the seller to try claim for a repair under warranty, if your lucky it fails well with in 12 months. Mine died at 11 months so I had to buy my own internal battery (took a lot of googling to find the right one) and begin minor surgery replacing it.
|  Sun Oct 09 2016 7:14am |
| Tyrefitter Member Since: 19 Jul 2015 Location: Bridlington East Yorkshire Posts: 3677      | I've got the thinkware 770 & it's a good bit of kit with many useful features but they are 250.
 Buckster,,I have the Thinkware 770 & was going to set it so it records when parked up but I'm worried about my battery going flat on the car as I have it hardwired.Have you connected yours to a battery pack.? Also mine seems to take about 40 minutes driving before the gps connects,at first I thought it was where I had it mounted so I moved it & it's still the same. Andy. Andy. 21 Ford Ranger Gone but not forgotten Focus RS Red Edition 2015 RRS AB Fuji. 2014 RRS SC Santorini 2016 VW Amarok 2014 RRS AB Fuji 2012 RRS Red Edition Fuji 2015 Nissan Navara 2012 RRS SE Santorini 2008 RRS White 2007 RRS Santorino | ||
|  Sun Oct 09 2016 7:36am |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156      | I have a Thinkware 770 hardwired in mine and have never had a battery issue, it is voltage sensed which you can set in the menu so it switches off if battery starts to get low. GPS connects within a minute or so but it is a RRS1 and not a solar whatever windscreen.
|  Sun Oct 09 2016 7:52am |
 What Col said, I have it hard wired and all ThinkWare have a voltage drop sensor that will switch it off if battery gets to low. I do sometimes get the GPS connection straight away and other times it can take a while before it connects. I have a work colleague that has one and his does the same  2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black 2013 SDV6 HSE Black Edition- Orkney Grey with Ebony & Ivory. LR Facelift RAI, Genuine G4 Expedition Rack, 4x Warn SBD-160 Spotlights, Warn 9.5XPS Winch, Mantec Underbody Protection and Sump Guard, Full Easy Lift Suspension Module, LR Light Guards, Light Force HTX230 Hybrid spotlights, 18” Compomotive PD1881 on 265/65/18 BF Goodrich KO2, ARB fridge, TuffTrek awning 😎 | ||
|  Sun Oct 09 2016 9:15am |
| Tyrefitter Member Since: 19 Jul 2015 Location: Bridlington East Yorkshire Posts: 3677      | Once mine as connected it will connect within seconds of turning ignition on unless it's been parked up over night then it takes longer.ill go into the settings & set it to park mode or whatever it is & set voltage,,what voltage have you guys set it to or will it be set to reccomended voltage.
|  Sun Oct 09 2016 10:29am |
| ShooterNeil Member Since: 14 Nov 2012 Location: Tamworth Posts: 422      | Thanks for the info cars been in body shop for 8 working days now for a wing and headlight and a bumper if it can't be welded 61 AB 5.0 supercharged rocket
|  Sun Oct 09 2016 3:22pm |
| Johnski Member Since: 02 Sep 2015 Location: North Wales & North Yorkshire Posts: 1407      | I think you should only be paying around £199.00 for the Thinkware F770 UK, not the £250 stated. I purchased one last week at the £199.00 Front & Rear HD.   | ||
|  Mon Oct 10 2016 12:13am |
| Pakolainen Member Since: 14 Mar 2016 Location: Helsinki Posts: 310      | Just installed a Blackvue 650 front and rear in the wife's car - (should have been going into my car) and am extremely happy with it. A touch sensitive but great all round package 2019 RRS P400e Autobiography
|  Mon Oct 10 2016 5:36am |
| Paulcp Member Since: 18 Apr 2013 Location: Suffolk Posts: 327    |
 Care to let us know where?   | ||
|  Mon Oct 10 2016 2:43pm |
| npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716    | other option is buy a F750, and do the firmware upgrade to the F770, as per flydrives thread a week or so ago
|  Mon Oct 10 2016 2:55pm |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156      | This is where mine came from. 199.00 for 16Gb  249.00 for 32GB both with Hardwire Kit.
| Paulcp Member Since: 18 Apr 2013 Location: Suffolk Posts: 327    | Thanks Col, I looked there and the 770 with F & R cameras was 249, front only @199.
|  Mon Oct 10 2016 3:57pm |
| Tyrefitter Member Since: 19 Jul 2015 Location: Bridlington East Yorkshire Posts: 3677      | The F&r are available from thinkware at 199 but with the 16gb instead of the 32.
|  Mon Oct 10 2016 6:54pm |
| Posting Rules
