Home > Technical > Rear prop rubber
Gilly1
Rear prop rubber
hi all, just inspected my rear propshaft rubber bearing and found the rubber to be shot, can anyone tell me if it's still best to change propshaft rather than try change rubber & bearing, I've also got a slight wine between 30/50 mph could this be the cause of it.
Is it still ok to drive ( short journeys) until repaired or replaced.
Post #507404 Sun Oct 09 2016 11:44am
General consensus is that changing the whole shaft is the better option. The bearing can be changed but if you're paying someone to do it it'll probably be no cheaper than a straight shaft swap. Changing the shaft also gives you a nice new UJ/CV at each end too. 2012 SDV6 - it's missing a couple of cylinders
Post #507405 Sun Oct 09 2016 11:54am
Gilly1
New shaft it will be then, just seems a bit pants paying that just because a rubber is worn, as you say new UJ/CV as well. Thumbs Up
Post #507413 Sun Oct 09 2016 1:53pm
Paddi
If it is just the rubber - some have reported good results from just filling it full of Sikaflex.
http://www.disco3.co.uk/forum/topic58033.h...p;start=30
A word of warning though; I've used this stuff for sealing up deck fittings and the hull to keel joint on my boat and no compromise has been made to make it user friendly or easily removable. Once you get it on your hands you just have to wait for it to wear off! Acetone shifts it before it is properly cured but you don't really want to be using a lot of that on your skin. 2008 MY Java Black TDV8 HSE
Post #507423 Sun Oct 09 2016 3:49pm
Gornal Hills
United Kingdom 2007 Range Rover Sport TDV6 HSE Cairns Blue
Hi, the whole shaft is better, just had mine changed last week. 30 min job and now it it sound again Thumbs Up 2007, HSE, Cairnes Blue, Factory tints, Love it !!!
Post #507433 Sun Oct 09 2016 5:13pm
Gilly1
Thanks, will use some sikaflex until I receive and get round to fitting new prop. Thumbs Up
Post #507510 Mon Oct 10 2016 1:27pm
Gilly1
Is this ok, or is it stay away and buy from island 4x4
http://www.ebay.co.uk/itm/172350761972?_tr...EBIDX%3AIT
Cancel that I just went with island 4x4 1 x Propshaft Rear RRS (GKN) TVB500370 TVB500390 LR037028 £190.00 can anyone confirm its correct part Please. Very Happy
Post #507727 Thu Oct 13 2016 2:19pm
