Home > Maintenance & Modifications > Slow speed clunk
DerrekL
Slow speed clunk
Got a noise form driveshaft/gearbox/something else? when I am in 1st 2nd gear. Kind of horrible feeling as if waiting for the horrible clunk noise (is only way I can describe this noise, almost like I am running over something for a few metres - hope that makes sense Exclamation ) to appear when moving slower in traffic. Thumbs Up RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #507191 Thu Oct 06 2016 4:05pm
Gornal Hills
United Kingdom 2007 Range Rover Sport TDV6 HSE Cairns Blue
Hi, just had the same with mine, exactly the same thing. I put a post on here and Disco Mikey suggested that it could well be the rear propshaft, had it done only yesterday and all seems fine now. When i saw it only half the rubber was connected to the fixing bracket hence it was knackered Thumbs Up (i need to thank mikey for the spot on info) Bow down 2007, HSE, Cairnes Blue, Factory tints, Love it !!!
Post #507266 Fri Oct 07 2016 3:03pm
DerrekL
Ah OK I wouldn't have thought of looking there!!! Shocked anyway thanks for the reply. Can you point me to any pictures/guides that you referenced to fix yours? Thumbs Up RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #507268 Fri Oct 07 2016 3:17pm
Gornal Hills
Hi again, i should of took a photo as a reference and to post on here but i didn't Embarassed It's not to easy to do a full inspection without a ramp but when mine was up in the air it was easy to see. Cost wise i had a price of £720,00 for the prop plus fitting but the nice warranty coughed up Bow down (thank god) You need to have a good look at it to confirm this or rule it out but i believe it is a common fault on these, hope this helps Thumbs Up 2007, HSE, Cairnes Blue, Factory tints, Love it !!!
Post #507278 Fri Oct 07 2016 4:57pm
DerrekL
OK thanks for the update. Nothing like getting under there and having a look Thumbs Up RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #507293 Fri Oct 07 2016 6:36pm
Gornal Hills
All the best with it, but certainly worth a look Thumbs Up 2007, HSE, Cairnes Blue, Factory tints, Love it !!!
Post #507295 Fri Oct 07 2016 6:41pm
