Home > Technical > Wheel bearing causing gear box fault
TALL DAVE
United Kingdom 2013 Range Rover Sport SDV6 HSE Lux Orkney Grey
Hi All
Has anyone heard off the front wheel bearing causing a gearbox fault message my local Indy suspects it's throwing out the speed sensors ?
Any thoughts?
Post #507083 Wed Oct 05 2016 11:08am
Socast
If there's play in the bearing then it could prevent the speed sensor from reading properly.
Post #507093 Wed Oct 05 2016 1:59pm
Camelrock
Would of thought you'd get abs faults than gearbox if a sensor was going down.. 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
1994 Dakar current
Post #507133 Wed Oct 05 2016 10:14pm
CornishRob
United Kingdom 2006 Range Rover Sport TDV6 HSE Sumatra Black
What fault exactly ?
If the front tyre's are different makes, then the gearbox can cause problems, specifically refusung to change up to 6th, except in "command shift" mode. (Caused by different rolling diameters of the tyre's).
Post #507259 Fri Oct 07 2016 1:03pm
nosmokenopoke
United Kingdom 2009 Range Rover Sport TDV6 Autobiography Zambezi Silver
I also agree with that.
The zf6hp26 has speed sensors in it so i cant see that the wheel bearing would have anything to do with it.
What codes you got when its read
Jon
Post #508269 Fri Oct 21 2016 7:47pm
TALL DAVE
All sorted now
Thanks for your input
Gearbox power flush, new filter and reset feels like a new car
Post #508273 Fri Oct 21 2016 8:06pm
nosmokenopoke
Wow Tall Dave. Wheel bearing to mega flush is far apart but like you said all fixed and driving so jobs a good one. Thumbs Up
Jon
Post #508275 Fri Oct 21 2016 8:12pm
