![]() | Home > General > Slight metallic squeak when turning left...occasionally?! |
| Paul_selby Member Since: 05 Sep 2016 Location: North Yorkshire Posts: 35
Hi . I would maybe try and work out which side it is coming from ( a passenger comes in handy!) then jack that side up. Check for any play top to bottom or left to right and excessive movement . Also jack both sides up and move the wheels lock to lock to see if the noise appears only under load . Hopefully this would narrow it down to a specific area . Hope this helps , Paul |
| kttlaweb Member Since: 08 Aug 2016 Location: Derbyshire Posts: 16
Update; I have located the squeak/squeal to the front offside wheel, and it can be heard occasionally when Jacked up and wheel rotated, the noise becomes more consistent the faster you travel. When the brakes are applied the noise stops...
Could well be the backing plate behind the disc or the shims that the brake pads sit in have been bent . I'd take the calliper off on the side in question . Check the pads are sat right and can be removed and replaced using nothing more than finger power. While they're out of the carrier (the bit that holds the pads) have a look at the backing plate and pad shims........just be careful not to damage a pad wear indicator lead if it has them . |
I have today stripped the brakes down and double checked everything... all appears to be OK with them...
| Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594
Wheel bearing. |
| ShooterNeil Member Since: 14 Nov 2012 Location: Tamworth Posts: 422
Stone guard catching the disks? 61 AB 5.0 supercharged rocket
| Sharpy1980 Member Since: 24 Sep 2016 Location: Kent Posts: 98
+1 for the wheel bearing, usually when I'm trying to comfirm a failing wheel bearing over the phone I usually ask the customer to listen when altering the steering angle slightly and/or braking to see if the noise changes/stops, you may find the noise only happens when steering in 1 direction only |
Checked the stone guard, all clear around there!
Yes mate, try jacking it up again but this time when you rotate the wheel apply some outward then inward pressure as you rotate it and you will probably feel the roughness, it will be easier to feel as it gets worse. |
