![]() | Home > Faults & Fixes > Front anti roll bar bushes |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4505 ![]() ![]() ![]() |
Picture 1 is the DR/ARC ARB's
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9090 ![]() ![]() ![]() |
1 is dynamic anti roll bar. 2 is the passive bar as fitted to Disco 3. Disco instructions won't help really. I think the front dynamic bar needs the body lifting a touch or something else removing first.
Gilly1 Member Since: 29 May 2015 Location: Somerset Posts: 203 ![]() ![]() ![]() |
Ahh that will explain why there different then lol, holly c**p part body lift just to fit ARB rubbers, LR really don't like making it easy for the home DIY"er.. |
T and S Norman might be able to help....? Visitor from fullfatrr.com
Thanks dr rob, will contact them if can't get round lifting front, has anyone managed to fit front ARB rubbers without lifting body up, I don't mind purchasing a (special spanner) if needed, I'm not even 100% sure that is the low speed rough road tapping/rattling I can hear, I get a bit of movement with pry bar, pretty sure it's not control/wishbone arms because my last sport had Definitive clunk when applied brakes at low speed and dealer had them changed before I completed sale. |
Hi Gilly,
Thanks paddi that's great help, |
trennaa Member Since: 01 Aug 2014 Location: Tasmania Posts: 4 ![]() ![]() |
Gilly I did mine last weekend and it's possible without the special tools but not the most enjoyable job I have done, a Flexi head ratchet spanner helps for sure but they are so tight so to get them started or nipped up tight I bent a ring spanner to get it up and over, I found the Flexi head ratchet spanner had a fair bit of play in the pivot when you put heaps of pressure on it and as it is so tight in there I found it easy to bend a spanner and leaver of the chassi etc. with a screwdriver handle and when there was nothing to lever off I put a chain on the ring spanner and had another person pulling the chain through the wheel arch with a screwdriver through the chain and levering off the chassi. I know it is not the most conventional way but it worked really well. |
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
There's no need to lift the body when replacing either set of bushes. Front require that the drive shaft be unbolted and lifted up, rear take 15 mins a side to do, it takes longer to jack up the car and remove the wheel than it does to change each bush. |
Thanks all for reply,s, I'm going into battle today & hopefully I come out victorious, 🙏 |
