Home > Technical > Fault codes
LJRH
Fault codes
Morning all,
Can anyone give any info on these two fault codes?
B1b02 low frequency coil signal not in range
B1c57 ignition circuit monitoring relay short to +/ ground, or open circuit.
My mechanic believes there's a control box that may need replacing but land rovers are not his forte. He believes that the other faults shown on diagnosis are all linked to this box. (Various faults including suspension light, Bluetooth etc).
Does anyone have any experience of this?
Many thanks.
Post #506583 Wed Sep 28 2016 8:27am
Disco_Mikey
My car has had these fault codes for 3.5 years, with no ill effects
Are you having any specific issues?
Post #506605 Wed Sep 28 2016 1:01pm
LJRH
intermittent suspension warning light, sometimes the radio doesn't work, that's about all.
A couple of times when the suspension light has come on, the car seems a bit 'wobbly'
Post #506606 Wed Sep 28 2016 1:08pm
Disco_Mikey
What suspension codes are stored?
Post #506634 Wed Sep 28 2016 8:29pm
LJRH
Not sure specifically, he just gave me a list.
U0434
C1119
U0132
U0182
U159
B1b57
B1b58
B1b02
B1b70
B1b80
B1c14
B1c57
B1c98
B1c99
U0155
B1b66
B1a56
B1a00
U3000
Post #506753 Fri Sep 30 2016 8:35am
Disco_Mikey
C1119 - Hydraulic pressure
Presumably in the ARC/DRM module? Suspect you may have a leakand/or low fluid Thumbs Up
Post #506755 Fri Sep 30 2016 9:16am
LJRH
What's an arc drm module?
Post #506760 Fri Sep 30 2016 9:33am
active anti roll bar.
Check fluid container on the drivers side by the air box
Post #506765 Fri Sep 30 2016 10:38am
LJRH
Sorry for the long reply, I've been lazy.
The fluid looks low, how high up in the bottle should it be? Near the top marker?
Post #507580 Tue Oct 11 2016 2:42pm
