![]() | Home > Maintenance & Modifications > Trolley Jack & Axle Stands |
| Tyrefitter Member Since: 19 Jul 2015 Location: Bridlington East Yorkshire Posts: 3677
you will be ok with a 2 ton jack as your only going to be lifting one corner at a time,,it also depends how much you want to spend & if the ground is level where your going to be jacking up.We use these & they are good if jacking up on uneven ground as they are wide.
| Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477
I use this one with the 6 ton stands: https://www.machinemart.co.uk/p/ctj3000g-3...-garage-j/ Aside from the strength (and it is worth noting that the 3-ton Clarke quick lift jack has been known to fail under the weight of a D3) you also get more height available. |
| Fish Member Since: 29 Jan 2014 Location: Glasgow Posts: 60
I went for this set http://www.sgs-engineering.com/garage-equi...xle-stands from SGS, very pleased with them and feel safe when working under all that steel |
| Blueskye1 Member Since: 10 Sep 2016 Location: Carmarthen Posts: 80
Thanks Gents..
| DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2026
I bought SGS after a lot |
| Plazmapete Member Since: 05 Jun 2016 Location: Cannock Posts: 118
I borrowed a 2 ton trolley jack and it wouldn't lift mine. Got a 3 ton sealey jack for around £35 and a pair of stands from argos around £20. |
| IRBails Member Since: 22 Nov 2013 Location: Wollongong Posts: 874
A little off topic but I am looking for a good 2 ton light Weight Bottle jack to carry in the car. I don't like the jack supplied and if I need to change a wheel would like a better solution. Wondering if any of you guys have found a good solution. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
Gents thanks again for your words of wisdom |
| tonywolf Member Since: 14 Sep 2015 Location: Devon Posts: 97
Hi IRBails, in answer to your query, I bought this item from LR Direct, and as you can see it fits nicely in the tool tray https://www.lrdirect.com/KAJ500151-supplie...ROVER.html Best Regards
Tony MY2014 SDV6 AB Dynamic |
| Danv8 Member Since: 20 Apr 2015 Location: Norfolk Posts: 378
That's the kit i received last week, it lifted and supported mine with absolutely no effort at all. Just be care full when you removing the axle stands when your finished, i raised the car up grabbed the axle stand and lifted the ratchet to free the support arm, it dropped down a wee bit quicker than i thought and i didn't quite move my little finger out the way in time. A week later and huge blood blister, swelling and rather tender joint, I'm slowly getting its use back..lol |
Cheers Dan
| Johnski Member Since: 02 Sep 2015 Location: North Wales & North Yorkshire Posts: 1407
I very recently purchased the same Jack but not with those stands, was very disappointed that not a trace of oil etc in the Jack at all, and it was extremely difficult to remove retaining clip.(badly bent).
| All times are GMT |
