Home > General > What angle would cause a "Range Rover Sport" to fl
Rolo
United Kingdom 2011 Range Rover Sport 3.0 TDV6 Autobiography Chawton White
I thought I'd discovered it today. Does anybody have the answer.
I'm in France and early this morning I was in a vineyard. Stupidly, I reversed into a shadow and discovered it was an 8ft drop with a very steep incline.
Soon as the rear wheels were over, I bottomed on the running boards and then couldn't drive forward. Climbed out carefully. I felt like the coach driver in the Michael Caine film, The Italian Job. I decided to continue the reverse.
So steep that the first to touch the ground were my exhaust mufflers which filled with soil and grass.
The descent ripped off my front bumper, but it was undamaged and easily re-fitted. I was glad to get on the level and then out the other side.
Gouges at the top were from the running boards.
So, how steep an angle will that have been ? It felt very unsafe and I was afraid of it flipping, but regular off-roaders think this was girl's play ! Do I get a badge ? Smile
Picture uploaded. Might be in gallery.
Gary
Post #506207 Fri Sep 23 2016 6:00pm
Buckster
Cant see the pic anywhere Gary? 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #506216 Fri Sep 23 2016 8:19pm
DrRob
Side inclines are more of an issue than front to rear. The Sport would have taken your scenario all in its stride Thumbs Up
Getting out was probably not a good idea in hindsight as the vehicle may not have held Whistle * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
I use www.glenrands.co.uk Great independent
Post #506219 Fri Sep 23 2016 9:01pm
Rolo
It's definitely uploaded. I am relying on McDonalds wifi, and the first time it was really slow. It's showing now.
Post #506280 Sat Sep 24 2016 8:04pm
Disco_Mikey
Post #506285 Sat Sep 24 2016 8:51pm
Rolo
Thanks, Mike.
Sends shivers down my spine each time I look at this. I'm no Eddie The Eagle. Sad
At the lower level, the gouges are from the exhausts. What's the tipping angle ? When Top Gear climbed the dam, wasn't there a cable tied to it ? Wimp.
Post #506286 Sat Sep 24 2016 8:57pm
Tim in Scotland
In the photo the bank looks almost vertical so even hardened winch challenge people would have second thoughts about going over backwards, even with their winch wire secured to something strong. You are lucky that you didn't damage more than your pride and the front bumper, I'm surprised you didn't smash the rear as well. Would be interested to know if you were in a) low ratio gears, b) off-road height and c) if before your rearward descent you tried to force the extended off-road height to come into action. You cannot set extended height, the car has to do it automatically, although there is a way to force it.
Also if your car has the Dynamic Response system fitted it has a nice extra for off-roaders in that it will electronically dislocate the rear anti-roll bars to allow even more wheel articulation off-road if wheels are flying - it was optional on 2.7HSE's and standard on TDv8's, S/C's and the 4.4 V8 Petrol but I don't know if it was fitted as standard to the later 3.0ltr V6 L320's like it is on the RRS2 HSE and Autobiography Dynamic cars.
I assume that you ended up on a lower level track and not in a pit too! Were you a lone car off-road too? I think you earned you badge and doubtless some clean underwear as well! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #506290 Sat Sep 24 2016 9:26pm
Rolo
My problem was I was already over the edge and sat on the middle of the chassis, running boards. Couldn't get any forward traction, wheels just spun as there was no weight on them. Looking back, maybe I could have reversed a few inches and then selected forward and powered out.
However, I'm not an off-reader, don't want to be an off-reader and wouldn't have mentioned it here only I would like to know how near to an accident of some magnitude I was/not. To put it into perspective, I'm concerned about high kerbs and these ........ 40 tyres. I'd welcome any advice on more practical, more durable, more comfortable tyre sizes. Suitable for winter travel, but not looking for snow & ice.
I turned the drive switch into hill climb and pressed the raise suspension button until my finger caught fire. Not sure if any of this had an effect, or not.
I'm impressed with the car for pulling through and the only bit I take pride in is putting the bumper back on. It was quite a scary moment for me. I only took the decision to go down into this pit, because the other side was banked, but not as steep as the ski slope I was on. The track to it was narrow causing me to do a 17-point turn to face it head on.
Here's another pic of the down slope. Maybe in the gallery, Mikey.
Obviously I made a big mistake in this event. The reason for it, other than lack of care, is that I was on farm tracks and had travelled from a crossroads and was reversing back towards it so I could then drive out left. What I'd forgotten is that the cross roads has a dog leg which goes around the sunken garden. A shadow from a tree coincided with the black hole and through my rear view camera, I had no reason for concern.
I'd welcome any advice on more practical, more durable, more comfortable tyre sizes. Suitable for winter travel, but not looking for snow & ice. November in Glen Etive, or Ullapool, etc.
Yours, from Bordeaux.
Post #506330 Sun Sep 25 2016 1:08pm
HemoRRS
Doesn't look as bad from that angle.
I believe the entry and exit angles are stated in the manual.
Post #506338 Sun Sep 25 2016 1:54pm
DrRob
It survived. Crack onto the next hill Thumbs Up
Drop down to Hampshire one day and Buckster and I will take you out on some hills to practice Thumbs Up * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
Post #506356 Sun Sep 25 2016 5:30pm
Johnski
Even if you think you will never go off road, I can thoroughly recommend The Land Rover Experiemce, run at different locations around the Country, to encompass steep inclines, rocky inclines sand driving along in water up to the max capabilities of car, observance procedure before doing anything, cameras are there to assist.
You tell them the model car you have and you can use that, or on a several day course try other models in the RR range.
Most scary bit for me was stopping half way down a steep incline where you aren't in your seat but held by seat belts. Not touching any foot psalms and using correct program to get you out of some instances is great fun and weird.
The main thing is, you are safe and car still in one hit, checking/planning could have prevented said incident, these courses point out things you may never have thought of. John
Post #506399 Sun Sep 25 2016 11:51pm
Rolo
Thanks all.
Post #506415 Mon Sep 26 2016 8:55am
